Linking Linux shared library 7 years 7 months ago #13261
  • Md. Shariful Alam Khan
I am trying to create a Firebird UDF using CT. As Firebird UDF require ib_util_malloc if you use String and I did that. But can't link the libib_util.so. I compile it for 32bit Linux using CT Typhon 32 on Fedora 28. As I am developing UDF for Firebird 1.5 which is 32bit that's why I am using Typhon 32. I copied libib_util.so on my project folder but still, it can't link libib_util.so. How to link it please help? Please see the attached screenshot.
Linking Linux shared library 7 years 7 months ago #13262
libib_util.so you try to link is from Linux64 Sub-System
you must install libib_util.so for Linux32 Sub-System,
if exists in Fedora 28 packages
Linking Linux shared library 7 years 7 months ago #13263
Where should I put the 32bit libib_util.so? In app folder or usr/lib folder?
Linking Linux shared library 7 years 7 months ago #13266
Yes
but it's better to install the 32bits OS package
