Incorrect installation 7 years 10 months ago #12934
  • Janis
  • Janis's Avatar Topic Author
Hi all.
I need to build small .so library with Typhon, but always
get error:
Fatal: Can't find unit system used by mytestlibrary
I can't understand what i need to install in Code Typhon for building Linux .so library from Windows.
I installed ALL what I found CT Center about Linux64, but not found
directory "x86_64-Linux64" with linux libraries.
Can some one explain to me step by step what I need to install ?
WBR
Janis
Incorrect installation 7 years 10 months ago #12935
Follow this tutorial
but for "x86_64-Linux"
Incorrect installation 7 years 10 months ago #12938
  • Janis
When i choice in menu Crossbuild/FreePascal 64bits/FPC64 build cross element x86_64-Linux
I always get this errors on the end of compiling log:
Could Not Find C:\codetyphon\fpcsrc\compiler\*.exe
Could Not Find C:\codetyphon\fpcsrc\compiler\utils\*.exe
Could Not Find c:\codetyphon\fpcsrc\utils\*.exe
Could Not Find c:\codetyphon\fpcsrc\fpcmade.*
Could Not Find c:\codetyphon\fpcsrc\Package.fpc
Could Not Find c:\codetyphon\fpcsrc\*.ppu
Could Not Find c:\codetyphon\fpcsrc\compiler\*.o
Could Not Find c:\codetyphon\fpcsrc\packages\*.o
The system cannot find the file specified.
Could Not Find c:\codetyphon\fpcsrc\installer\*.o
Could Not Find c:\codetyphon\fpcsrc\utils\*.o
Could Not Find c:\codetyphon\fpcsrc\packages\xforms\fd2pascal*
Stage 5: Copy Files and Units
A subdirectory or file ..\..\fpc\fpc64 already exists.
File not found - *.*
0 File(s) copied
[ERROR]: win64 Cross Element for x86_64-linux Param:xxxx NOT Exists
What do I wrong ???
Incorrect installation 7 years 10 months ago #12940
Please try to build with
FPC32 => x86_64-Linux cross element
and use Typhon32 to build your App
Incorrect installation 7 years 10 months ago #12942
  • Janis
Ok, I go step by step with clear installation:
1. Installing CT studio/center (Console window)
2. Run CT center
3. Menu: Compiler/Free Pascal remove and build all
All Ok, no errors
4. Menu: Typhon-IDE/Typhon IDE remove all and Build BigIDE
All Ok, no errors
5. Download cross toolchains
check: win32-x86_64-linux.7z and
win64-x86_64-linux.7z and
All Ok, no errors
6. Downloas OSes libraries
check: i386-linux.7z and
x86_64-linux.7z
All Ok, no errors
7. Menu: CrossB/FreePascal 64 Bits/FPC64 build cross element x86_64-Linux
and get errors:.
0 File(s) copied
Incorrect installation 7 years 10 months ago #12943
All steps from 1-6 OK
7. Menu: CrossB/FreePascal 32 Bits/FPC32 build cross element x86_64-Linux
We have the same problem and in LAB CT 6.70.
FPC64 on Windows has some Cross-Build problems, I hope to fix-it
Incorrect installation 7 years 10 months ago #12945
  • Janis
How long time take to fix this bug?
When bug will be fixed, where You write info about this?
Incorrect installation 7 years 10 months ago #12948
Sir it's FreePascal source problem
I don't know
