There is no TDatapacketReaderClass registered for this kind of data-stream 8 years 4 months ago #11806
  • Md. Shariful Alam Khan
I am trying to save TRxMemoryData to file as following but I am getting error "There is no TDatapacketReaderClass registered for this kind of data-stream". Please see attached screenshot.
SaveToFile(FileName, dxXML) - same error
SaveToFile(FileName, dxAny) - same error
SaveToFile(FileName) - same error
There is no TDatapacketReaderClass registered for this kind of data-stream 8 years 4 months ago #11807
  • Thank you received: 236
pl_RX don't has TDataPacketReader class for XML export
You must use (or modify)
codetyphon\fpcsrc\packages\fcl-db\src\base\xmldatapacketreader.pp
XMLDatapacketReader unit
has and register the TXMLDatapacketReader = class(TDataPacketReader)
Please have a Look and at these:
codetyphon\fpcsrc\packages\fcl-db\src\base\csvdataset.pp
pl_PascalSCADA\source\database\fpsbufdataset.pas
pl_ZMSQL\source\zmbufdataset.pas
There is no TDatapacketReaderClass registered for this kind of data-stream 8 years 4 months ago #11808
I added XMLDatapacketReader on uses but still got same error
There is no TDatapacketReaderClass registered for this kind of data-stream 8 years 4 months ago #11809
Please give us more info
for your project
There is no TDatapacketReaderClass registered for this kind of data-stream 8 years 4 months ago #11810
All I am trying to store some data in TRxMemoryData and load it. It's not so special, just simple save and load. But now I can't save it. Below is my TRxMemoryData stucture:
with TableExtract do
with FieldDefs.AddFieldDef do
DataType := ftInteger;
DataType := ftString;
Name := 'DatabaseType';
Name := 'TableName';
with FieldExtract do
Name := 'TableType';
Name := 'FieldName';
Name := 'FieldType';
Name := 'FieldSize';
Name := 'FieldNullable';
Name := 'FieldDataType';
