XML Document and Generic convert from Delphi to CT 8 years 4 months ago #11795
  • Md. Shariful Alam Khan
I have a delphi unit which I need to use in CT 6.5. On my Delphi unit I have used xmldom, XMLIntf, XMLDoc, System.Generics.Collections, what are the unit I have to use in CT? Please help. Please see the attached screenshot what I want to convert. I only need the which unit do I have to use.
XML Document and Generic convert from Delphi to CT 8 years 4 months ago #11796
C:\codetyphon\fpcsrc\packages\fcl-xml\src\dom.pp
or
C:\codetyphon\typhon\components\BaseUtils\laz2_dom.pas
C:\codetyphon\typhon\components\pl_Generics\source\generics.collections.pas
You can search in CodeTyphon directory "for files" or "in files" with
CTCenter=>Page Tools=>Find Files Tool
XML Document and Generic convert from Delphi to CT 8 years 1 month ago #12738
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
Sternas Stefanos wrote: You can search in CodeTyphon directory "for files" or "in files" with
Not found on Linux - is this a windows only function?
XML Document and Generic convert from Delphi to CT 8 years 1 month ago #12739
CTC has the same Internal tools for ALL Host OSes
The following user(s) said Thank You: wolfram
XML Document and Generic convert from Delphi to CT 8 years 1 month ago #12740
  • Klaus Riesterer
Thank You Sir !
