Upgrading to CT 6.50 issue 8 years 4 months ago #11786
  • patrick
  • patrick's Avatar Topic Author
Hi guys,
I just updated my CT system from version 6.40 to 6.50 and got some issue with my reports (Tfr Reports). Now some fields do not render the accentuated strings. It appears like Unicode is not implemented in some cases. It is rather weird effect as some reports still show the accentuated letters.
Maybe some advice
Thanks in advance
Biobytes
Upgrading to CT 6.50 issue 8 years 4 months ago #11787
Always you can use pl_FortesReport package from CT 6.40
Please, can you attach a test project to find the problem ?
Upgrading to CT 6.50 issue 8 years 4 months ago #11788
  • patrick
Thank for your reply Sternas,
I tried to move to Fortes report package but it is not fine for me as In cannot get it in French.
I try to prepare a test project to post it asap
Biobytes
Last edit: by patrick.
Upgrading to CT 6.50 issue 8 years 4 months ago #11789
Ok
Upgrading to CT 6.50 issue 8 years 4 months ago #11812
  • patrick
After several tries, I found why some fields in my lzReports did not render accentuated characters. The problem comes from the "longtext" fields defined in the MySQL database. After changing the "longtext" format to "VarChar(6000)", the problem disappeared and the reports displayed correctly the accentuated strings. This is really a bug in TfrReport package.
I noted also that Image field appearing in report preview is not printed when sending the report to the printer (!?)
Maybe some comments
Biobytes
Upgrading to CT 6.50 issue 8 years 4 months ago #11813
I think we solve the problem with images in pl_FortesReport ver 6.5
Upgrading to CT 6.50 issue 8 years 3 months ago #11838
  • patrick
The issue with the emmbedded image in fortes report still persists. The problem appears when the image object is inserted in a header band.
Biobytes
Upgrading to CT 6.50 issue 8 years 3 months ago #11839
we will try to fix and this
