IDE fails to build 8 years 6 months ago #11618
  • Roger Boisjoli
  • Roger Boisjoli's Avatar Topic Author
I try to install CT on Ubuntu 16.04. The IDE build fails, bot small and big. System suggests I reinstall CT. Did that many time, still no luck. VT Version 6.4, Revision 006400.
Build Typhon64 Small IDE x86_64-linux-gtk2 for Linux
Clean Typhon IDE Setings
[INFO]: Clean Typhon64 IDE Setings finish
Restore Typhon Default IDE Setings
[INFO]: Restore Typhon64 Settings finish
make -C packager/registration
make[1]: Entering directory '/usr/local/codetyphon/typhon/packager/registration'
/bin/rm -f ../units/x86_64-linux/fcllaz.ppu
/usr/local/codetyphon/fpc/fpc64/bin/x86_64-linux/ppcx64 -MObjFPC -Scghi -O1 -g -gl -l -vewnhibq -Fu. -FE. -FU../units/x86_64-linux -Cg -dx86_64 fcllaz.pas
Hint: (11030) Start of reading config file /home/roger/.fpc.cfg
Hint: (11031) End of reading config file /home/roger/.fpc.cfg
Free Pascal Compiler version 3.1.1 [2018/04/22] for x86_64
Copyright (c) 1993-2018 by Florian Klaempfl and others
(1002) Target OS
(1002) Target OS: Linux for x86-64
(3104) Compiling fcllaz.pas
/usr/local/codetyphon/typhon/packager/registration/fcllaz.pas(11,3) Fatal: (10022) Can't find unit db used by fcllaz
Makefile:2803: recipe for target 'fcllaz.ppu' failed
make[1]: Leaving directory '/usr/local/codetyphon/typhon/packager/registration'
Makefile:3253: recipe for target 'registration' failed
mv: cannot stat 'typhon': No such file or directory
mv: cannot stat 'typhonstart': No such file or directory
mv: cannot stat 'typhonbuild': No such file or directory
mv: cannot stat 'tools/ctres': No such file or directory
mv: cannot stat 'tools/ctlrstofrm': No such file or directory
[INFO]: Clean Tools Directory
[ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build
Terminate Action at 22-4-18 12:34:34
Total time: 00:00:10.761
ExitCode : 0
Last edit: by Roger Boisjoli.
IDE fails to build 8 years 6 months ago #11622
- did you install System Libraries ?
- more info for your Linux Box, RAM etc... ?
