Installing external package rebuilds everything and fails 8 years 10 months ago #11241
  • Hans-Peter Gygax
  • Hans-Peter Gygax's Avatar Topic Author
I'm using Typhon32 big ide on Windows 10.
I tried to compile an external Lazarus package (Castle Engine). I converted the package using "Convert old CT files to new". Because the package couldn't find the Generics package, I added a requirement for the "pl_Generics".
Strangely, trying to rebuild the IDE with that new package resulted in *all* the packages being recompiled, which eventually failed with "Fatal: No memory left".
Restarting the IDE and re-installing the package always results in that same error.
Installing external package rebuilds everything and fails 8 years 10 months ago #11243
Remove some packages or use Typhon64
FreePascal need a lot of memory...;)
Installing external package rebuilds everything and fails 8 years 10 months ago #11263
  • Hans-Peter Gygax
Thank you Sternas,
Installing the package with Typhon64 worked.
Can I use Typhon64 on Windows to build and debug 32-bit Windows executables and DLLs ?
EDIT: you have answered this question in another thread (yes it works): www.pilotlogic.com/sitejoom/index.php/fo...-typhon64-on-windows
Last edit: by Hans-Peter Gygax.
