XMLDocument UTF8 Problem 9 years 2 months ago #10941
  • ct_user
  • ct_user's Avatar Topic Author
By requesting a xml-result encoded in UTF8,
i found a problem concerning UTF8-Charachters.
in ct6.10 fine.
In ct6.20 char > 255 converted into ?
CT 6.10
function T_DVB_VIEWER2.GET_RS_VERSION: Boolean;
i : integer;
RESPONSE : TStringList;
SS : TStringStream;
XML : TXMLDocument;
NODE_ROOT : TDOMNode;
NODE_iver : TDOMNode;
// Get Data
RESPONSE := TStringList.Create;
Self.HttpGetText( Self.F_URL, RESPONSE );
SS := TStringStream.Create( RESPONSE.Text);
SS.Position := 0;
XML := NIL;
ReadXMLFile(xml, SS);
END;
SOLUTION for CT 6.20
i : integer;
SS : TStringStream;
XML : TXMLDocument;
// Get Data
SS := TStringStream.Create( RESPONSE.Text, tEncoding.UTF8);
SS.Position := 0;
XML := NIL;
END;
It should be a reason of how a TStringStream is now created without adding tEncoding.UTF8.
prior it works. now you have to extend.
take care
ct_user
Last edit: by ct_user.
XMLDocument UTF8 Problem 9 years 2 months ago #10942
thanks for your solution.
It's FPC source improvement
FreePascal SVN 36758 "TStringStream now observes encoding, bug ID 30508"
Info1
Info2
FreePascal bugtracker link
CodeTyphon use the latest FreePascal...
and we track->build->test FPC SVN source 2-5 times per day... :)
The following user(s) said Thank You: ct_user
