6.15 bugs 9 years 6 months ago #10749
  • Aleksandr
  • Aleksandr's Avatar Topic Author
Hi. An error occurs when trying to update the list of libraries from the host. Screenshot attached. Any ideas? Thank you!
Last edit: by Aleksandr.
6.15 bugs 9 years 6 months ago #10752
Please give us more info
-Your OS
-Your CT version
-Your internet connection type
etc...
6.15 bugs 9 years 6 months ago #10753
  • Aleksandr
1. Debian 8
2. CT 6.15 (But it shows how 6.10)
3. Fast ethernet
P.S. Everything worked in version 6.0
6.15 bugs 9 years 6 months ago #10754
Please read this forum topic
The problem is sudo root privileges
CTCenter (NOT Typhon IDE) must execute from a user with sudo root privileges
read and this
6.15 bugs 9 years 6 months ago #10755
  • Aleksandr
But I run with rights SUDO...
6.15 bugs 9 years 6 months ago #10756
Did you install "System Libraries" ?
try and this
sudo apt install libcanberra-gtk-module libcanberra-gtk3-module
6.15 bugs 9 years 6 months ago #10757
  • Aleksandr
I did it. But it did not help.
6.15 bugs 9 years 6 months ago #10758
My suggestion :
download CT 6.15 zip file and make full CodeTyphon installation
I test CT 6.15 in one of our Debian (latest) 8 PCs, all are OK
Please, your Desktop ?
6.15 bugs 9 years 6 months ago #10759
  • Aleksandr
I've already reinstalled it twice (6.15). Error repeating.
I have now installed version 6.0. Everything is working. What's wrong with version 6.15?
6.15 bugs 9 years 6 months ago #10760
CT 6.00 use wget for connections
CT 6.15 use native pascal for connections
Can you zip and attach here
your PC info ?
6.15 bugs 9 years 6 months ago #10761
  • Aleksandr
File Name: system_info.7z
File Size:2 KB
6.15 bugs 9 years 6 months ago #10762
1) you must have in your /etc/sudoers file
a last line
user ALL=(ALL) NOPASSWD: ALL
2) open CTCenter with command
codetyphon
not
sudo codetyphon
attach file line 55
[WARNING]: CTCenter run for root or sudo user, this is NOT correct...?????
The following user(s) said Thank You: Aleksandr
6.15 bugs 9 years 6 months ago #10763
  • Aleksandr
Yes, it works! Thank you!
6.15 bugs 9 years 6 months ago #10764
and have fun
