Typhon32 build bigIDE failure,only small IDE 9 years 8 months ago #10566
  • dorry
  • dorry's Avatar Topic Author
win7 32 bit install codetyphon OK,but build typhon bige IDE by codetyphon,but only builded small IDE.
i had try o lot of times. i could not find the reason?please help?
Typhon32 build bigIDE failure,only small IDE 9 years 8 months ago #10567
please ready this
Typhon32 build bigIDE failure,only small IDE 9 years 8 months ago #10569
  • dorry
thank sir,I recompiled the typhon bigide from your suggestion,but return error.
win7 32bit ,ram:10GB
C:\codetyphon\typhon\ide\ct_popuppkgs.pas(253,7) Note: (5025) Local variable "xfile" not used
C:\codetyphon\typhon\ide\ct_popuppkgs.pas(18,3) Hint: (5023) Unit "TreeFilterEdit" not used in ct_popuppkgs
(3104) Compiling ct_popupcomppages.pas
C:\codetyphon\typhon\ide\ct_popupcomppages.pas(201,8) Note: (5027) Local variable "xPageIndex" is assigned but never used
C:\codetyphon\typhon\ide\ct_popupcomppages.pas(203,10) Note: (5025) Local variable "ss1" not used
C:\codetyphon\typhon\ide\ct_popupcomppages.pas(39,5) Note: (5029) Private field "TDlgPopupCompPages.fDirForPkgs" is never used
C:\codetyphon\typhon\ide\ct_popupcomppages.pas(16,36) Hint: (5023) Unit "TreeFilterEdit" not used in ct_popupcomppages
(3104) Compiling .\frames\ct_desktop_options_extra.pas
C:\codetyphon\typhon\ide\.\frames\ct_desktop_options_extra.pas(18,44) Hint: (5023) Unit "IDEUtils" not used in ct_desktop_options_extra
(3104) Compiling .\frames\ct_embedded_designer_settings.pas
C:\codetyphon\typhon\ide\ct_main.pp(1023,27) Warning: (4104) Implicit string type conversion from "AnsiString" to "WideString"
C:\codetyphon\typhon\ide\ct_main.pp(1023,53) Warning: (4105) Implicit string type conversion with potential data loss from "WideString" to "AnsiString"
C:\codetyphon\typhon\ide\ct_main.pp(1024,26) Warning: (4104) Implicit string type conversion from "AnsiString" to "WideString"
C:\codetyphon\typhon\ide\ct_main.pp(1024,51) Warning: (4105) Implicit string type conversion with potential data loss from "WideString" to "AnsiString"
C:\codetyphon\typhon\ide\ct_main.pp(1025,28) Warning: (4104) Implicit string type conversion from "AnsiString" to "WideString"
C:\codetyphon\typhon\ide\ct_main.pp(1025,67) Warning: (4105) Implicit string type conversion with potential data loss from "WideString" to "AnsiString"
C:\codetyphon\typhon\ide\ct_main.pp(7453,19) Warning: (5033) Function result does not seem to be set
C:\codetyphon\typhon\components\pl_UIB\lib\i386-win32\win32\uib.ppu:uib.pas(53,10) Error: (1026) Compilation raised exception internally
Fatal: (1009) No memory left
Error: C:\codetyphon\fpc\fpc32\bin\i386-win32\ppc386.exe returned an error exitcode
make[2]: *** [Makefile:4141: typhon.exe] Error 1
make[2]: Leaving directory 'C:/codetyphon/typhon/ide'
make[1]: *** [Makefile:4559: ide] Error 2
make[1]: Leaving directory 'C:/codetyphon/typhon/ide'
make: *** [Makefile:3267: ide] Error 2
make: Leaving directory 'C:/codetyphon/typhon'
Error: (IDE) Build IDE: stopped with exit code 2
Error: (TyphonBuild) Building IDE: Building IDE failed.
?Ҳ? C:\codetyphon\typhon\*.exe
[ERROR]: Typhon32 BIG-IDE NOT Build
Terminate Action at 2017/2/28 10:05:27
Total time: 00:05:10.019
ExitCode : 0
Last edit: by dorry.
Typhon32 build bigIDE failure,only small IDE 9 years 8 months ago #10570
Big IDE has too many packages for your PC memory
The only solution is to
-build Typhon32 small IDE CTCenter=>Typhon-IDE=>Typhon 32, Build Small IDE
-open Typhon32 IDE, select only the packages you need info
-and rebuild IDE
Typhon32 build bigIDE failure,only small IDE 9 years 8 months ago #10585
  • Avra
  • Avra's Avatar
dorry wrote: thank sir,I recompiled the typhon bigide from your suggestion,but return error.
On 32bit windows you have just a little more then 3GB available...
Typhon32 build bigIDE failure,only small IDE 6 years 5 months ago #14756
  • Pierluigi Filippone
  • Pierluigi Filippone's Avatar
For experience, to build big IDE you need minimum 4Gb RAM
