cross java-jvm 9 years 10 months ago #10367
  • gulyone
  • gulyone's Avatar Topic Author
  • Thank you received: 6
is there any tutorial (easy or not) to crossbuild from win32 CT to jvm-java?
I ask this because I did just several attempts with a BASIC program (no dependencies on packages, even not fcl) and CT IDE complains there is no fpc.cfg for the desired target. then the compilation hangs with exit code 1 -Tjava invalid parameter
as i said, i built ppcjvm.exe all went ok, I switched from "use ct internal build engine" to "ct uses external build engine" after I downloaded all libraries and engine related to all-jvm-java. I even manually added -FI...\units\java\rtl , and any others where fpc installed object files and .class files
cross java-jvm 9 years 10 months ago #10368
  • gulyone
n.b
the only thing i did not try is to exit IDE and try to compile in an OS command box, manually using fpcjvm.exe instead of fpc.exe dispatcher
cross java-jvm 9 years 10 months ago #10369
Cross-build in CodeTyphon is one click action 4 years now...
cross java-jvm 9 years 10 months ago #10370
  • gulyone
yep sternas, i am no noob, i built that, and downloaded all related java libraries.. always got IDE messagebox warning "no fpc.cfg" for the selected target, then I press compile button on a simple as possible
program xxxx;
end.
and CT 5.9 hangs ont a red line in messages "-Tjava invalid parameter exit code = 1"
Last edit: by gulyone.
cross java-jvm 9 years 10 months ago #10371
  • gulyone
I am going to put here some scnshots, in an hour (currently rebuilding the whole CT), you'll see what happens
cross java-jvm 9 years 10 months ago #10373
  • gulyone
cross java-jvm 9 years 10 months ago #10375
CPU-OS =jvm-java
The OS is java
The CPU must be jvm
cross java-jvm 9 years 10 months ago #10376
  • gulyone
ok Sir, thank you, will try tomorrow and repport (currently adding 4GB ram more on my laptop to get 8GB total)
cross java-jvm 9 years 10 months ago #10377
OK
and have fun
cross java-jvm 9 years 10 months ago #10378
  • gulyone
ok last attempt... I must have miss something
I looked for JDK and java SDK contents to see if I could find that 'jvm-java-java.exe' but it doesnt exist, so I have no more clue.
my purpose was to test cross-compilation for later use, actually it works fine with no effort windows <=> linux ubuntu
I'm about to give up with javacrap lol :-)
