ct ver 5.9 problem 10 years 1 week ago #10164
  • himo
  • himo's Avatar Topic Author
Hello;
I upgraded using ct center from 5.8 to 5.9 and i have a broblem !!!!
Repeated keystrokes in code editor of typhon only not in others applications.
Infos:
OS: Linux Mint 18
PC: HP Pavillon
Ram : 8Go
HDD: 500
Typhon: 5.9 Beta2
ct ver 5.9 problem 10 years 1 week ago #10165
we will check and fix
ct ver 5.9 problem 10 years 1 week ago #10171
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
I also use 5.9 on Mint 18 but all works fine
ct ver 5.9 problem 10 years 1 week ago #10172
  • Klaus Riesterer
Sorry my last post was wrong - using CT 5.80
ct ver 5.9 problem 9 years 11 months ago #10254
  • Klaus Riesterer
Where is TRxCurrEdit in 5.9? It was in 5.8!
ct ver 5.9 problem 9 years 11 months ago #10255
we will check this
ct ver 5.9 problem 9 years 11 months ago #10256
did you mean TCurrencyEdit ?
this comp (TCurrencyEdit) exists in CT 5.8 and LAB CT 5.9
ct ver 5.9 problem 9 years 11 months ago #10257
  • Klaus Riesterer
No Sir,
I mean TRxDBCurrEdit from RX DBAware-Tab. It is in 5.8 but I can't find it in 5.9
ct ver 5.9 problem 9 years 11 months ago #10258
Sir,
It's in "RX DBAware" Typhon components page
ct ver 5.9 problem 9 years 11 months ago #10259
  • Klaus Riesterer
OK, found the problem:
in 5.80 it was named dbcurredit now in 5.90 its rxdbcurredit
Problem solved - Thank you Sir
ct ver 5.9 problem 9 years 11 months ago #10260
ct ver 5.9 problem 9 years 11 months ago #10289
  • himo
Hello;
Repeated keystrokes in code editor of CT 5.90 Persists.
is there a solution ?
Linux Mint 18.
ct ver 5.9 problem 9 years 11 months ago #10290
we will check this
