How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9767
  • lestroso
  • lestroso's Avatar Topic Author
Hi to everybody,
is there a simple manner to play a sound once or when i want??
I have already seen all the Ocean example... but they are too complicated!!!
A simple manner?? a simple Library?? Any Idea??
Thanks A lot,
lestroso :blush:
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9772
my suggestion is pl_OpenALS library of CodeTyphon Studio
CodeOcean has samples and all runtime libraries
codetyphon\CodeOcean\0_libraries
The following user(s) said Thank You: lestroso
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9773
  • lestroso
Thanks a lot Sternas.....I'll take a look!!! Best regards,
Lestroso :woohoo:
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9775
  • Fred
  • Fred's Avatar
There is also uos (github.com/fredvs/uos).
Libraries for Windows, Linux, RPI, FreeBSD, OSX are included.
Examples for LCL, fpGUI, MSE and console are included too. (working out of the box).
Sadly the pl_UOS library included in Code Typhon is out of date (use, please, last commits of github.com/fredvs/uos)
PS: @ Sternas, you are welcome, when you have time, to commit the (lot of) changes from uos-GitHub. :blush:
Last edit: by Fred.
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9777
  • lestroso
Dear Fred,
I thank you so much!!!! I appriciate a lot your answer!!! I 'll take a look.. i hope will easy to use...Thanks a lot again,
Lestroso :woohoo:
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9778
  • lestroso
Dear friend, i have found a way very easy to play a sound but only in windows,,..works also well in windows10!!!!
Best regards,
lestroso :woohoo:
Playing Sounds
Windows only: using the Windows API
You can use the Windows API to play e.g. wav files:
uses MMSystem;
sndPlaySound('C:\sounds\test.wav', snd_Async or snd_NoDefault);
The fail-safe way, which will allow appending paths and nonlatin file names is:
sndPlaySound(pchar(UTF8ToSys('C:\sounds\test.wav')), snd_Async or snd_NoDefault);
This works very fine in Typhon!!!!! Cheers, Lestroso :woohoo:
Last edit: by lestroso.
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9779
  • Fred
  • Fred's Avatar
@ lestroso : Nice but you will not be able to change volume, nor do a seek, nor apply DSP effect, nor have view meters, ...
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9780
  • lestroso
Hi Fred,
it's complicated your library....and there're no instructions how to use it. Also webplayer go for me in Crash!!!
In any case thanks a lot...
best regards,
lestroso :woohoo:
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9781
  • Fred
  • Fred's Avatar
In the Code-Typhon forum : www.pilotlogic.com/sitejoom/index.php/fo...-version-1-0-is-here
Also in the wiki : wiki.freepascal.org/uos
But the best instructions are in the comments of uos.pas code and in examples.
With what os (Windows/Linux/osx) ? When do it crash ?
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9782
  • lestroso
Hi Fred!!
Thanks for theinstructions links...i'll see them as soon as possible....
Well webplayer crash.. i don't know why...when i push button to play...Crash..... I'm using WINDOW10 and HP PAVILLON G SERIES 4 gb ram corei5 64bit.
One question Fred... Is it possible with your library enclose a sound in the final exe??? without loading external data folder???
Best Regards,
Lestroso :lol:
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9783
  • Fred
  • Fred's Avatar
Oooops, I just tested it with Windows 10 and, indeed, it crash. :(
I will fix it asap (aaargh, sure new pseudo-protection done by Microsoft for web-access ).
The good news is that webplayer tested on last Linux and FreeBSD is working ok.
If you store your audio-file into resource (.res) and compile it with the exe => of course it is possible.
Last edit: by Fred.
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9786
  • Fred
  • Fred's Avatar
lestroso wrote: Hi Fred!!
Well webplayer crash...
Lestroso :lol:
OK, fixed in last release (github.com/fredvs/uos)
Many thanks to note it.
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9787
  • lestroso
Your welcome Fred....Thanks again a lot...
but do you know how to enclose sound as resource in .rsc file in typhon?? Thanks Fred....
Bye
Lestroso :(
How To PLAY a sound wav or mp3 in my Project?? 10 years 4 months ago #9788
  • Fred
  • Fred's Avatar
lestroso wrote: but do you know how to enclose sound as resource in .rsc file in typhon??
Lestroso :(
wiki.freepascal.org/Lazarus_Resources
Last edit: by Fred.
