Linux Arm cross Build 10 years 6 months ago #9465
  • angelo
  • angelo's Avatar Topic Author
Hi Have Problem to build from win32 to Linux-Arm
I have follow all instruction but when try to compile have an error on "RegisterFCl" Ca't found "Process"
Linux Arm cross Build 10 years 6 months ago #9466
can you give us more info ?
-Host OS
-CodeTyphon Version
-Target OS
-Target CPU
-Target Platform (GTK2, QT) ?
-Os Libraries for arm-linux?
-etc
Linux Arm cross Build 10 years 6 months ago #9467
  • angelo
Host Os (Win10 64)
CodeTyphon Version 5.7
Target OS Linux
Target CPU arm
Os Library for Arm linux "arm-linux-Raspbian"
Linux Arm cross Build 10 years 6 months ago #9468
If use use arm-linux-Raspbian Os Library
you must read this
-Did you Build FPC32 Cross arm-linux--RapberryPi element ? (not simple arm-linux)
Linux Arm cross Build 10 years 6 months ago #9471
  • angelo
I have follow exactly this Guide Step by Step.
Linux Arm cross Build 10 years 6 months ago #9472
  • angelo
Another Think, I have an old Virtual Machine with CodeTyPhon Ver. 5.6 and i can compile without any problems.
Linux Arm cross Build 10 years 6 months ago #9473
we will try to check and fix and this
Linux Arm cross Build 10 years 6 months ago #9475
We found the problem
a guick fix:
try to clear FPC Source directory, before build
