Errors report 10 years 7 months ago #9387
  • Milen
  • Milen's Avatar Topic Author
I was with CT 5.60 on Windows 7 64bit.
BUT:
1. When open the BIG IDE, the CPU works at about 20%. It stops if I only open menu for window>select layout. Do not restore any layout, only open menu item.
2. BGRABitmap3D do not work - I try the example from FreePascal WIki - you know - 3D pyramid. I try also the example in CodeOcean folder, but - result always is some squished vertical line in the window.
... etc.
I try to deinstall and install new version - CT 5.70.
It is NOT succeed. I try second try with the same result. I try on another PC - with UBUNTU 5.10 64bit in this case. The result is the same as on my Windows 7 machine.
I post here the last row from the install log (on Win 7 64bit):
..\binSettings\settings\x86_64-win64-win32\styphon\pl_ExtentIDEcfg.xml
9 File(s) copied
..\binSettings\settings\alluserschemes\zct_black.xml
..\binSettings\settings\alluserschemes\zct_blackred.xml
..\binSettings\settings\alluserschemes\zct_blue.xml
..\binSettings\settings\alluserschemes\zct_bluelite.xml
..\binSettings\settings\alluserschemes\zct_buenanoche.xml
..\binSettings\settings\alluserschemes\zct_darkwolf.xml
..\binSettings\settings\alluserschemes\zct_desert.xml
..\binSettings\settings\alluserschemes\zct_liteblue.xml
..\binSettings\settings\alluserschemes\zct_nortonic.xml
..\binSettings\settings\alluserschemes\zct_pascalclassical.xml
..\binSettings\settings\alluserschemes\zct_solarized.xml
..\binSettings\settings\alluserschemes\zct_solarizednight.xml
12 File(s) copied
[INFO]: Restore Typhon64 Settings finish
Compile Typhon64 Win64
C:/codetyphon/fpc/fpc64/bin/x86_64-win64/make -C packager/registration
make[1]: Entering directory 'C:/codetyphon/typhon/packager/registration'
C:/codetyphon/fpc/fpc64/bin/x86_64-win64/rm.exe -f ../units/x86_64-win64/fcllaz.
ppu
C:/codetyphon/fpc/fpc64/bin/x86_64-win64/gmkdir.exe -p ../units/x86_64-win64
C:/codetyphon/fpc/fpc64/bin/x86_64-win64/ppcx64.exe -MObjFPC -Scghi -O1 -g -gl -
l -vewnhibq -Fu. -Fu../../../fpcsrc/rtl -FE. -FU../units/x86_64-win64 -g- -dx86_
64 fcllaz.pas
Hint: (11030) Start of reading config file C:\codetyphon\fpc\fpc64\bin\x86_64-wi
n64\fpc.cfg
Hint: (11031) End of reading config file C:\codetyphon\fpc\fpc64\bin\x86_64-win6
4\fpc.cfg
Free Pascal Compiler version 3.1.1 [2016/03/01] for x86_64
Copyright (c) 1993-2015 by Florian Klaempfl and others
(1002) Target OS: Win64 for x64
(3104) Compiling fcllaz.pas
makefile:2763: recipe for target 'fcllaz.ppu' failed
make[1]: Leaving directory 'C:/codetyphon/typhon/packager/registration'
makefile:2731: recipe for target 'registration' failed
[ERROR]: Typhon64 Small-IDE IDE NOT Build
Build Typhon64 BIG-IDE for Win64
CodeTyphon Studio 5.70 Setup for Windows64
Settings: Platform=Win32/64 Multiarch Mode=1
1) Run CodeTyphon Center (CTC)
11) -- Platform (widget) Setup
12) -- Multi-Architecture Setup
3) Remove FreePascal
4) Remove and Build FreePascal
5) Remove Typhon IDE
6) Remove and Build Typhon IDE
7) Remove ALL
8) Remove and Build ALL
9) EXIT
>>> Select an action (press 1..9 key):
Errors report 10 years 7 months ago #9388
-did you have any other FPC version in your PC ?
-did you have Antivirus ?
-did you have any other make.exe in you "OS Path" directories ?
My suggestion is to open CTCenter and execute CodeTyphon=>"Remove and Build ALL"
Save->Zip- and attach here, the CTC Action log info
We want to see and FPC 64 bit building log not only Typhon IDE Building
For BGRABitmap3D, we try to fix this problem
Errors report 10 years 7 months ago #9389
For pl_BGRABitmap library
please try this 7z file from LAB CT 5.8
Errors report 10 years 7 months ago #9390
  • Milen
I apologize, it seems that the problem was with my PC - the "Application Experience" Service of Windows was Disabled. Now the CT 5.70 was successfully installed.
BGRAbitmap3D do not work also in 5.70, but your file:
pl_BGRAbitmap.7z make it to work!
Thank you, very much!
Errors report 10 years 6 months ago #9455
  • Wilk
  • Wilk's Avatar
I have installed new (clean) version of CodeTyphon in version of 5.7 (Windows). When I change the dimensions (in object inspector) of the form at 1920x1080 (width x height) I get an error as an screenshoot (in attachment). Same error in Typhon32 and Typhon64:
Someone has same problem?
In Lazarus 1.6 (in older version too) I can easily adjust form dimensions at 1920 x 1080 in object inspector without any errors. :)
Last edit: by Wilk.
Errors report 10 years 6 months ago #9456
Use lazarus then Sir :laugh:
or
don't use embedded form designer
Errors report 10 years 6 months ago #9457
  • Wilk
  • Wilk's Avatar
CodeTyphon has already lot of components and libraries after installation. In Lazarus I should install now every single component what I need by myself. It takes a lot of time.
I guess this error with form dimensions 1920 x 1080 is a BUG in CodeTyphon.
There is a chance to correct this error in the future?
Without embedded form designer my work in this project will be much harder.
Last edit: by Wilk.
Errors report 10 years 6 months ago #9461
we try to find a fix for this
is the last problem in embedded form designer...
