Typhon leaks where Lazarus doesn't 10 years 9 months ago #9115
  • Avra
  • Avra's Avatar Topic Author
I have attached a minimalistic demo project where you can see that Typhon leaks but Lazarus doesn't leak. Please take a look and see if it can be fixed, because this is a show stopper for Typhon use with one of my projects. It is interesting to know that Typhon leaks on 'test2.json' but it doesn't leak on 'test1.json'. Lazarus does not leak on 'test1.json' and it does not leak on 'test2.json'.
Everything was tested on Win7SP1 64 bit (real pc, not virtual), with Lazarus and Typhon both 32 bit.
For Typhon, heap trace test results with leak were the same for CT5.5, CT5.6 and today built LAB CT5.6.4.1.
For Lazarus, heap trace test results without any leak were the same for both old Laz48732+FPC2.6.5 and for new Laz51535M+FPC3.1.1 built today.
[EDIT:]
Forum cuts attached file names in a strange way, so here in text I say that first picture is Typhon leaking, and second is Lazarus not leaking with the same code.
Last edit: by Avra.
Typhon leaks where Lazarus doesn't 10 years 9 months ago #9118
my suggestion is to use and Lab CT 5.7
I think we solve these problems
The following user(s) said Thank You: Avra
Typhon leaks where Lazarus doesn't 10 years 9 months ago #9119
  • Michal
  • Michal's Avatar
My test has given a different result:
Lazarus 1.6RC2 Win32 on Win32
CT56_57-current-32 on Win64
CT56_57-current-64 on Win64
Microsoft Windows [Wersja 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Wszelkie prawa zastrzeżone.
f:\Lazarus16rc2\ctleak>leakbugdemo.exe
test2.json
    Tick : -1,
    Now : "",
    PowerUpMoment : "",
    TotalDaysRunning : -1.0000000000000000E+000,
    DeviceID : -1,
    FirstPage : -1,
    LastPage : -1,
    CurrentPagePointer : -1,
    OverwriteOldEvents : false,
    MinLogLevelFilter : -1,
    StackFrameCorrupted : false,
    StackValid : [false, false, false, false, false, false, false],
    StackMinFree : [-1, -1, -1, -1, -1, -1, -1],
    FrameValid : [false, false, false, false, false, false, false],
    FrameMinFree : [-1, -1, -1, -1, -1, -1, -1],
    Sim : [false, false, false, false],
    DI : [false, false, false, false, false, false],
    DO : [false, false, false, false, false, false],
    AI : [false, false, false, false, false, false, false, false],
    AO : [false, false, false],
    MCUCSR : -1,
    ProcessScanCounters : [-1, -1, -1, -1, -1, -1, -1]
Heap dump by heaptrc unit
452 memory blocks allocated : 36263/37600
452 memory blocks freed     : 36263/37600
0 unfreed memory blocks : 0
True heap size : 163840 (96 used in System startup)
True free heap : 163744
C:\CT56_57\ctleak32>leakbugdemo.exe
test2.json
    Tick : -1,
    Now : "",
    PowerUpMoment : "",
    DeviceID : -1,
    FirstPage : -1,
    LastPage : -1,
    MCUCSR : -1,
663 memory blocks allocated : 41153/43200
663 memory blocks freed     : 41153/43200
C:\CT56_57\ctleak64>leakbugdemo.exe
test2.json
    Tick : -1,
    Now : "",
    PowerUpMoment : "",
    DeviceID : -1,
    FirstPage : -1,
    LastPage : -1,
    MCUCSR : -1,
645 memory blocks allocated : 51957/54248
645 memory blocks freed     : 51957/54248
True heap size : 196608 (160 used in System startup)
True free heap : 196448
Michal
Typhon leaks where Lazarus doesn't 10 years 9 months ago #9120
Sir, where is the problem ?
Typhon leaks where Lazarus doesn't 10 years 9 months ago #9140
  • Avra
Sternas Stefanos wrote: Sir
I thought I did use LAB 5.70. Shouldn't revision 005641 release be Lab CT 5.70?
Typhon leaks where Lazarus doesn't 10 years 9 months ago #9141
  • Avra
Michal wrote: My test has given a different result
Thank you very much for testing. It is strange that you do not have any leaks. I will test after pc restart and test on another pc...
Last edit: by Avra.
