OnAfterShow 11 years 3 months ago #7674
  • atlandev.ct
  • atlandev.ct's Avatar Topic Author
Hello all,
I don't know if is there a possible in CT to change some pascal behavior.
But I often used this sort of code in my old time with Delphi
FormOnShow
PostMessage(Self.Handle, WM_AFTER_SHOW, 0, 0);
WM_AFTER_SHOW defines like that: WM_AFTER_SHOW = WM_USER + $FF;
It's very usefull when you want to launch some automatic function or else but to be sure that your form is already shown.
So my question is can you add OnAfterShow like OnShow on form ?
Thanks.
Last edit: by atlandev.ct.
OnAfterShow 11 years 3 months ago #7675
First: we don't have any problem to make changes to LCL or to FreePascal
both at upcoming CT ver 5.4 are heavy modified
Second: the problem is, Delphi it's a Windows only IDE and CT it's a MultiOS-MultiPlatform IDE,
add MS Windows functionality to CT don't work on No-Windows Platforms in most of cases.
so, sorry but we can't
OnAfterShow 11 years 3 months ago #7676
  • atlandev.ct
That seem understandable :dry:
Thanks for the answer.
Do you have any idea how can I simulate this behavior with CT.
Do you think a delay in a thread perhaps ?
[SOLVE] a simple timer after all :silly:
