CT settings 11 years 4 months ago #7581
  • atlandev.ct
  • atlandev.ct's Avatar Topic Author
Hello everyone,
2 more questions...
1- if i save "..\AppData\Roaming\typhon32" and ."..\AppData\Roaming\typhon64" and i restore it after an update is that all my settings (color, window, jedi format, etc) will be preserved ?
2- if i install some new components should i reinstall them before restore my settings after updating ?
cheers CT,
Last edit: by atlandev.ct.
CT settings 11 years 4 months ago #7583
backup all CT user files and restore later, it's not the right way
because we make a lot of changes at CT Core System
My suggestion is to save color, window, jedi format, etc to external files from IDE options pages
and import these files later after CT update or after CT rebuild.
The following user(s) said Thank You: atlandev.ct
CT settings 11 years 4 months ago #7584
  • atlandev.ct
ok sir, I got it.
Thanks you.
