Compatibility 11 years 4 months ago #7580
  • atlandev.ct
  • atlandev.ct's Avatar Topic Author
Hello everyone,
I'd like to know - how can I be sure that my application developed on windows 7/64 is perfectly compatible with linux or mac ?
Should i follow a particular lead or compiled it on a linux or mac at each developmental stage ?
best regards
Last edit: by atlandev.ct.
Compatibility 11 years 4 months ago #7582
Any CodeTyphon project can build and run to any supported OS
(simple load and build)
Some libraries info don't work on some OSes
and this is the only problem, for sample you can't use lz_ActiveX library to MacOS
Please don't forget, CT it's a true "Native" Mutli-OS Programming Studio and NOT "Scripting" Programming Studio.
The following user(s) said Thank You: atlandev.ct
Compatibility 11 years 4 months ago #7611
  • avra
  • avra's Avatar
atlandev.ct wrote: I'd like to know - how can I be sure that my application developed on windows 7/64 is perfectly compatible with linux or mac ?
For a start, you should read this:
wiki.lazarus.freepascal.org/Multiplatform_Programming_Guide
Compatibility 11 years 4 months ago #7615
Sorry Sir
but this help link is an old theoretical study for Lazarus IDE
and has nothing to do with CodeTyphon
