TFPList sorting not working for me 11 years 5 months ago #7464
  • gustavo tolson
  • gustavo tolson's Avatar Topic Author
Dear all,
I have succesfully used this TList sorting construct in Delphi 7 under Windows XP but cannot get it to work in Typhon with Ubuntu 14.04. The construct I'm using is (from the Free Pascal forum) below but it generates the following error:
popan_u07.pas(386,29) Error: Identifier not found "SortLorenzByValue".
Could someone please post a working example?
Best regards,
Gustavo
uses ...math;
type
TLorenz = class
a,b,c:string;
v:integer;
function SortLorenzByValue(Item1: Pointer, Item2: Pointer):Integer;
Result:=CompareValue(Item1,Item2);
procedure RunMe;
aList:TList;
aList:=TList.Create;
try
for i:=0 to 9 do
aLorenz:=TLorenz.Create;
aLorenz.a:='Hello World';
aLorenz.v:=Random;
aList.Add(aLorenz);
aList.Sort(@SortLorenzByValue);
finally
for i:=0 to aList.Count-1 do
TLorenz(aList).Free; //TList.Free deletes the references but does not free it
aList.Free;
Last edit: by gustavo tolson.
TFPList sorting not working for me 11 years 5 months ago #7470
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
Hi uk301,
nothing can work in the piece of code you post.
SortLorenzByValue is missing some parts in its definition (type conversion..).
You don't use the index [ i ] to free the elements of the list.
Below a full example + the source fully commented (easier with syntax colors ;))
Have fun !
Warning: Spoiler!
TFPList sorting not working for me 11 years 5 months ago #7471
  • gustavo tolson
Many thanks for your prompt reply. I regret the omissions in my previously posted code but I copied it verbatim from the source you eloquently quote. Thanks to your post I have found my mistake.
Cheerio.
