Remove virtual desctop in designer. 11 years 5 months ago #7428
  • Alexandr
  • Alexandr's Avatar Topic Author
Greetings!
How to hide/remove that?
Remove virtual desctop in designer. 11 years 5 months ago #7430
Is not possible yet..., Sir
we will add this to our To-Do List
Remove virtual desctop in designer. 11 years 5 months ago #7431
  • Alexandr
What package create it? Mb I can remve it :)
Remove virtual desctop in designer. 11 years 5 months ago #7435
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
a bit more tricky than just a package to remove
I did a patch :P
Version used : 5311 (last experimental)
Be careful, keep a copy of you current c:\codetyphon\typhon\bin32\typhon.exe just in case !
Start an empty project and edit the following files:
C:\codetyphon\typhon\components\baseideintf\idewindowintf.pas
Warning: Spoiler!
c:\codetyphon\typhon\ide\environmentopts.pp
Warning: Spoiler!
c:\codetyphon\typhon\ide\main.pp
Warning: Spoiler!
For the next steps, we will have to do some modification directly in the IDE in the Form Designer
Load c:\codetyphon\typhon\ide\frames\desktop_options.pas
Go to the Form Designer
Copy the checkbox "Use Embedded Form Designer (need restart IDE)" and paste it (duplicate)
Rename it as "UseVirtualDesktopCheckBox"
Change its text to "Use Virtual Desktop in Embedded Form Designer (need restart IDE)"
Move the CheckBox to place it under "Use Embedded Form Designer..." (for consistency)
Now we can go to the Source Editor
Warning: Spoiler!
c:\codetyphon\typhon\ide\ct_emb_formeditor.pas
Warning: Spoiler!
Ok, now that all the modifications have been done.
In Typhon, go in Tools/Build Typhon with profile: Optimized IDE
It will take a few minutes
After this, you will find the option in Tools/Options/Environment/Desktop/Use Virtual Desktop in Embedded Form Designer (need restart IDE) :)
It is working fine for me.
To-Do Done ;)
The following user(s) said Thank You: Alexandr
Last edit: by Tony_O_Gallos.
Remove virtual desctop in designer. 11 years 5 months ago #7442
We fixed this Guys
@Tony_O_Gallos thanks for your help
Remove virtual desctop in designer. 11 years 5 months ago #7451
  • Alexandr
Oh, THANKS! A very helpful!
