Profiling 11 years 9 months ago #6639
  • Luca
  • Luca's Avatar Topic Author
Do you have a plan to include a profiling tool in CT?
For example FPProfiler ?
I tried to select gprof option in the project options dialog without success (I'm using Windows version of CT).
Luca
Profiling 11 years 9 months ago #6641
We will Try
Profiling 11 years 9 months ago #6642
  • lag.co.nr
  • lag.co.nr's Avatar
@Luca
Try following these steps:
1) Check "Project/Project_options/Compiler_options/Debugging/Generate_code_for_gprof"
2) Build your application.
3) Run the executable file(it's better to run it outside IDE).
4) Close the application that you've just runned and look for a new file("gmon.out") that's created,most likely, in the same directory as the executable. If your application ends up with an error, the file "gmon.out" won't be wrtitten to disk.
5) Run "gprof executablefilename > profilestats.txt" within the same directory as "gmon.out" and executablefilename are. This will take some time(minutes).
6) Open the "profilestats.txt" file to see some stats.
Note: I'm not sure gprof works great with multithreaded applications.
Profiling 11 years 9 months ago #6643
  • Luca
Thanks for reply.
Cannot compile if I select gprof. I read some topics but it's seems there are some issues in windows.
I installed Gwin and the other libraries but problem in compilation still remains.
Luca
Last edit: by Luca.
