CT 5.0 first impression 12 years 2 months ago #5936
  • Alfred
  • Alfred's Avatar Topic Author
  • Thank you received: 5
CT 5.0 ... again a very nice release ... thanks Sternas !!
Installing on Win8.1 64 bit: perfect. Compiling and running applications: perfect.
Cross from Win8.1 to Linux ARMHF (for RapberryPi and BBB) : can be made to work, but again with some changes.
Toolchain
Download hardfloat binaries for ARM hardfloat with Control Center.
Rename everything with "armeb" to "arm" (toolchain-directory as well as executables).
Crossbuild ScriptsWin
Rename "x_FPC_Build_Cross_armeb_linux_hardfloat.bat" to "x_FPC_Build_Cross_arm_linux_hardfloat.bat".
Some changes to this script are necessary ... see included batch-file.
Result:
Running CodeTyphon apps on my Raspberry Pi !!
(RaspberryPi libraries are needed, as well as some compiler directives [as seen in the script])
However, it would be nice if an "out-of-the-box" was (made) possible (Sparta).
Thanks again Sternas.
File Name: x_FPC_Buil...loat.txt
File Size:6 KB
The following user(s) said Thank You: kenlee
Last edit: by Alfred. Reason: atachment gone ... ?
CT 5.0 first impression 12 years 2 months ago #5938
we will add to next CT release your fix
CT 5.0 first impression 12 years 2 months ago #5941
  • Vbxler
  • Vbxler's Avatar
That would be fantastic if that were possible!
Thank you Mr. Sternas and Mr. DonAlfredo! :)
CT 5.0 first impression 12 years 2 months ago #5942
Your wish, it's our Command :)
we uploading :
lin32-arm-linux--eabihf.7z
lin32-arm-linux--BeagleBoard.7z
lin32-arm-linux--RapberryPi.7z
lin64-arm-linux--eabihf.7z
lin64-arm-linux--BeagleBoard.7z
lin64-arm-linux--RapberryPi.7z
win32-arm-linux--eabihf.7z
win32-arm-linux--BeagleBoard.7z
win32-arm-linux--RapberryPi.7z
win64-arm-linux--eabihf.7z
win64-arm-linux--BeagleBoard.7z
win64-arm-linux--RapberryPi.7z
For Tests..
PS: please we want Libraries from BeagleBoard....
CT 5.0 first impression 12 years 2 months ago #5971
  • Gyula Kampfner
  • Gyula Kampfner's Avatar
Why is the form in designer in the left window empty?
(check the picture attached)
CT 5.0 first impression 12 years 2 months ago #5972
  • Gyula Kampfner
The issue reported in the CodeTyphon Studio -> CT Lab Version and News -> CT LAB ver 5.00 topic, message #5851 is still exists in the final release.
CT 5.0 first impression 12 years 2 months ago #5973
Sir,
go to Options=>Desktop and Uncheck "Use Embedded Form Designer"
until we solve the problem...with 2 Source Editors....
Please Don't forget, CT Embedded Form Designer is Multi-OS, NEW Ability
and work OK with 1 Source Editor
CT 5.0 first impression 11 years 11 months ago #6381
  • Bobi
  • Bobi's Avatar
Commonly I am glad to use.
I have some trouble, the main top form is missed :
I resolve when make dense whole place, also very useful:
Be conveniently, if message window is splited like Source/Designer windows with watches- a time editing and compiling to seen Messages, wehen program started in debug mode, to auto swich to Watch list. If need to can swich manuali with tab buttons above them.
Also like Delphi, to can search need component by name, because list of them is unlimited and some times not known in which group is it.
Have other remarks, more of them is commonly with Lazarus, or components.
Thanks for All! :)
CT 5.0 first impression 11 years 11 months ago #6382
you can search need component by name by open "View Components" Window
Delphi is a small part of CodeTyphon... :blush:
The following user(s) said Thank You: Bobi
CT 5.0 first impression 11 years 11 months ago #6466
  • Bobi
  • Bobi's Avatar
Thanks- very useful components window! :)
I was understand trouble:
When in Object Inspector I try to paste text in value of some property with keyboard shortcuts Ctr+V, He do not paste as corresponding property value, but paste in program text. In this case I do not have possibilities to paste in component properties inside in Object Inspector and must to write with keyboard. With Shift+Insert and mouse working.
