CT 4.8 troubles 12 years 7 months ago #5363
  • Javor
  • Javor's Avatar Topic Author
So so, updated to CT 4.8 and troubles began. Now I cannot cross-build any application from Windows to Linux for arm. Here's so far what I've tried after fails to build:
- rebuilt toolchains
- re-downloaded Linux for arm libraries
- from CTC -> CrossBuild -> FreePascal 32bits -> FPC32 build cross element arm-linux <- tried to build and got those errors:
Could Not Find C:\codetyphon\fpcsrc\compiler\utils\*.exe
Could Not Find c:\codetyphon\fpcsrc\utils\*.exe
Maybe that's the reason for my troubles. Or am I missing something?
Also there's a bug in one of the units in pl_ZeosDBO package...
Most important for me now is to be able to cross compile from Windows to Linux for both PC and arm...
Last edit: by Javor.
CT 4.8 troubles 12 years 7 months ago #5365
  • Luis Gutierrez
  • Luis Gutierrez's Avatar
Run CTC with admin privilegies?? i download yesterday CT 4.8, i prepare crossbuild for linux i386 and android arm, and all works fine...
i have other errors, for example, cross compile for linux with LCLwidget custom draw, and show this error:
c:\codetyphon\fpc\bin\i386-win32\i386-linux-ld.exe: cannot find -lXext
with LCLwidget QT4 works fine, customdraw for windows target works fine...
CT 4.8 troubles 12 years 7 months ago #5369
  • Javor
No idea what's wrong. Previous version compiled my projects with ease :(
Apart from packages renamed, everything should work fine, but odd...
No probs with admin rights - I run CT on Win XP with an admin account. What I mean is nothing changed since my last build, except for those errors.
Downloading new versions of libraries and finding out they're now put in \binLibraries\, rather than where I had them till now, e.g. in \Libraries folder solved my problem. Sorry for the false alert.
CT 4.8 troubles 12 years 7 months ago #5370
my suggestion is to post here your "build log"
and the "system info" from CTCenter
CT 4.8 troubles 12 years 7 months ago #5386
  • frederico augusto marques
  • frederico augusto marques's Avatar
Upgrading my application from CT 4.50 to CT 4.80 (Ubuntu 12.04 LTS - Cross Compiler Linux to Win32) , with FreeSpider CGI, Fortes Report and ZeosDBO. All works Fine !!!
Thanks a lot Pilotlogic and sternas.
CT 4.8 troubles 12 years 7 months ago #5388
have fun
CT 4.8 troubles 12 years 5 months ago #5534
  • Marius
  • Marius's Avatar
Hello, i have found a bug in CT4.8 and maybe there is time to fix it in CT4.9.
You can not build Debian binary package from IDE because the script uses "lazbuild". This executable has been renamed in "typhoonbuild"
I hope it will be corrected.
Thank you.
CT 4.8 troubles 12 years 5 months ago #5535
we will fix this
CT 4.8 troubles 11 years 10 months ago #6579
  • Marius
  • Marius's Avatar
Thank you.
i have the same problem in 5.1. I hope that you will fix this in 5.20.
Thank you.
Last edit: by Marius.
