How can i compile and use RC file on CT4.7? 12 years 8 months ago #5216
  • goldqq
  • goldqq's Avatar Topic Author
On Delphi have "brcc32" , but I don't know laz/ct with what tools? how does it work ?
thanks.
How can i compile and use RC file on CT4.7? 12 years 8 months ago #5217
Do you want to build *.res or *.lrs files?
because RC files are the start-plasma for *.res files in old C++ programming style
How can i compile and use RC file on CT4.7? 12 years 8 months ago #5218
  • goldqq
Yes sir , I want to build *.res files , but I won't do. please teaching me.
How can i compile and use RC file on CT4.7? 12 years 8 months ago #5219
  • goldqq
or how can to build *.lrs files? thanks`!
How can i compile and use RC file on CT4.7? 12 years 8 months ago #5220
Use ctresbuilder.exe (32 or 64bit is the same) codetyphon\typhon\bin32
or from Typhon IDE ->tools->Resource builder
or from CTC tools->Resource builder
is external program with source... codetyphon\typhon\tools\ctresbuilder
Then just: new file *.res or *.lrs => drop or open files and => save as
is very simple
The following user(s) said Thank You: goldqq
How can i compile and use RC file on CT4.7? 12 years 8 months ago #5221
  • goldqq
Ok. I See, thank you very much.
How can i compile and use RC file on CT4.7? 12 years 8 months ago #5222
Thanks Sir, have fun
