Typhon IDE 4.60 cannot load project correctly 12 years 10 months ago #4958
  • Abdellah Al'Arief
  • Abdellah Al'Arief's Avatar Topic Author
Because of wrong result of FormatCurrency function, as i posted before (and still not be answered), so i tried to upgrade my Typhon IDE from 4.4 to 4.6. But worse, my project from Typhon IDE 4.4 can not loaded correctly in Typhon IDE 4.6. The message "External Sigsev" appeared when form that load database show. Well, i know about the message "External Sigsev", i check maybe there were any object that have not initialized was accessed, but none found.
So i move back to 4.4 version, and project none exception message appeared. To be more clearly, i attach my project in this post in
dl.dropboxusercontent.com/u/41480422/yatimmandiri_2.7z
it uses mysql database, zeos. Database script can be found in 'db' folder, i dump it with heidisql manager. mysql lib can be found same in executable file folder. This project can load correctly without any problem with Typhon IDE 4.4, so if you can load it correctly with typhon IDE 4.60, please tell me. another information, this application is dedicated for Indonesian user, so pardon me if you don't understand.
Thanks for any response.
altaifa.com
Last edit: by Abdellah Al'Arief.
Typhon IDE 4.60 cannot load project correctly 12 years 10 months ago #4959
we try to help you
can you post the name of the form that load database
Typhon IDE 4.60 cannot load project correctly 12 years 10 months ago #4962
  • Abdellah Al'Arief
thanks mr, maybe i used the term 'load' incorrectly. what i meant was, "please compile/run the program, and you will get exception 'External Sigsev'. I had checked it, maybe there was something with accessing object before correct initialization in my code. But, none i found. until now, i don't know, what because what error raised. I had tried to remove suspected forms from my project, and error still be raised.
altaifa.com
