CT Crash 13 years 2 weeks ago #4662
  • gulyone
  • gulyone's Avatar Topic Author
  • Thank you received: 6
using CT on windows 7
put a TAAText control from Extra Text page on a form
inspect all properties, find all the effects ones , see the strange characters, try to edit such property = CT Crash
suggestion =
1) remove this package from CT installation (pl_ExtTExt) until it becomes stable and mature, because all of its components have the same crash behavior after windows shows up an "out of memory error"
- important -
on page Shape Objects, got a TplText and a TplTextBezier, with a connexion property. I suppose that property wiats for a TplText component , BUT, if you select whatever TplText component you droped on a form, the field property keeps going empty.
I suppose that's another Major Bug.
CT Crash 13 years 2 weeks ago #4663
packages pl_ExtTExt and pl_GaiaGIS are "Experimental"
We put these pkg to ver 4.5 to get help from users
and please don't forget:
CodeTyphon Studio is NOT a product it's a free project,
so we want help.
CT Crash 13 years 2 weeks ago #4665
  • gulyone
yep
and that is why I explain what did happen, in the hope it helps you, not to condamn
CT Crash 13 years 2 weeks ago #4666
