in Dll project :Hwd := WidgetSet.AllocateHWnd(@Wnd 13 years 1 month ago #4528
  • dorry
  • dorry's Avatar Topic Author
Help?
in Dll project :Hwd := WidgetSet.AllocateHWnd(@WndProc); Hwd always is "0"?
and in Other project Hwd := WidgetSet.AllocateHWnd(@WndProc),HWD<>0 OK.
so
in Dll project :Hwd := WidgetSet.AllocateHWnd(@Wnd 13 years 1 month ago #4548
  • 4aiman's Avatar
It would've been helphul to supply some info on what you're trying to achieve here.
I can suggest you're trying to create some kind of a window in your dll.
So maybe you should try other way around like this or this ?
Or maybe you need to look into this one more time too.
Or maybe it'll be easier to make your own TWinControl descendant..
The following user(s) said Thank You: dorry
Last edit: by 4aiman. Reason: typo
in Dll project :Hwd := WidgetSet.AllocateHWnd(@Wnd 13 years 1 month ago #4563
  • dorry
Thanks sir,
After i have tried Application.initialize ,now ok!
