FileAssociation component 13 years 5 months ago #4036
  • lainz
  • lainz's Avatar Topic Author
Please add this component I've created for file association.
Attached the latest version.
It can add a program to Windows Default Programs in control panel.
FileAssociation component 13 years 5 months ago #4046
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
already done from several versions.
Open CodeTyphon menu General->File association
Last edit: by Miquel Matas.
FileAssociation component 13 years 5 months ago #4076
  • lainz
miquelmatas wrote: already done from several versions.
This is not for CodeTyphon installer UI... is a Component! (for Lazarus / CT IDE) Reusable for any Windows application.
Also it has a feature that your file association doesn't have: Default Programs file association ( msdn.microsoft.com/en-us/library/windows...144154(v=vs.85).aspx )
Is the same as wiki.freepascal.org/FileAssociation
But i've improved it to 'unregister' the file association when you want.
BTW this sub-forum is just for suggestions to forum or for CT too?
Last edit: by lainz.
FileAssociation component 13 years 5 months ago #4078
please attach the file again
zip first
FileAssociation component 13 years 5 months ago #4081
  • Miquel Matas
Sorry... :( I misunderstanded you....
Cheers!
Miquel.
FileAssociation component 13 years 5 months ago #4082
Forget it Sir
Typo error... :dry:
FileAssociation component 13 years 5 months ago #4091
  • lainz
No problem :side:
Here is the fileassociation.zip, inside there's the updated version.
File Name: fileassociation.zip
File Size:3 KB
