Another possible suite of audio components. NewAC 13 years 7 months ago #3538
  • Curt
  • Curt's Avatar Topic Author
Is it possible to get the NewAC suite of audio components converted to
a Lazarus/FPC format and included in CT?
I have tried and after a large amount of conversion and downloading
required dlls I still have problems.
I am hoping someone smarter than me can convert them and include in CT.
The author has released them as freeware along with sources but it is created for Delphi.
I need some good audio components (Non VST or ASIO needed) and have not had much luck with the ACS.
Here is the home page:
symmetrica.net/newac/
Thanks,
Curt
Another possible suite of audio components. NewAC 13 years 7 months ago #3539
we will test this
Another possible suite of audio components. NewAC 13 years 7 months ago #3541
  • fredvs
  • fredvs's Avatar
You can use also UOS (United OpenLib of Sound).
github.com/fredvs/uos
or zip package :
sites.google.com/site/fiensprototyping/U_OS_Test.tar.gz
@ Sternas : you are welcome to add uos in CT if you want.
Last edit: by fredvs.
Another possible suite of audio components. NewAC 13 years 7 months ago #3542
  • Curt
You know I have currently got the uos libraries
in my code. I haven't got it all figured out yet.
It may work after spending more time on the learning curve.
But I thought the NewAC system might be more intuitive
for me.
Basically what I would like to have in my app is
the ability to record live audio from the default sound
card/system. Record it to a file and also monitor it on
the computer.
Thanks for your reply.
Curt
Another possible suite of audio components. NewAC 13 years 7 months ago #3543
  • fredvs
  • fredvs's Avatar
the computer.
Take a look at simplerec.lpi in uos.
All you have to do is unzip the package and load the simplerec.lpi with lazarus.
Another possible suite of audio components. NewAC 13 years 7 months ago #3544
  • Curt
Tried it got "Invalid Number of Channels" error.
I know it is me blah!!
Working on it.....
Last edit: by Curt.
Another possible suite of audio components. NewAC 13 years 7 months ago #3545
  • fredvs
  • fredvs's Avatar
What OS do you use ? (Windows 32/64, Linux 32/64, Mac Osx 32 ?)
Another possible suite of audio components. NewAC 13 years 7 months ago #3552
  • Curt
Win7 x64 Core I7 8Gb Ram
Another possible suite of audio components. NewAC 13 years 7 months ago #3557
  • fredvs
  • fredvs's Avatar
Are you using Lazarus 64 bit or Lazarus 32 bit ?
I have not tested the rec example 64 bit in windows ( i have no Windows 64 bit to test it ).
Have you the same problem when compiling with Lazarus 32 bit ?
