Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3217
  • Arioch
  • Arioch's Avatar Topic Author
I just updated my Ct 3.10 to 4.00 from N:\CodeTyphonIns\install.bat
(Win7 x64 rus)
After i run CT Center and issued "Lazarus 64bit Build BIG IDE" i see few errors in the log:
         Build Lazarus BIG-IDE for Win64
ERROR: package not found: ..\lazarus\components\pl_Brook\pl_brook.lpk
ERROR: package not found: ..\lazarus\components\pl_Greyhound\pl_greyhound.lpk
C:/codetyphon/fpc/bin/x86_64-win64/make -C tools
make[1]: Entering directory `C:/codetyphon/lazarus/tools'
Makefile:2332: warning: overriding recipe for target `.'
Makefile:2330: warning: ignoring old recipe for target `.'
echo
?? ?뢮? ?? ? ?࠭ (ECHO) ?⪫?祭.
winprndialogs.inc(233,17) Hint: Local variable "lpp" does not seem to be initialized
2287 lines compiled, 0.5 sec
11 hint(s) issued
?"?????'????? "?????????>???Ő?? ?????'?? Printer4Lazarus 0.5" ??????????????
TLazPackageGraph.CheckIfCurPkgOutDirNeedsCompile  Compiler custom params changed for pl_KControls 1.3
Compiling .\source\kgrids.pas
kgrids.pas(1260,58) Warning: An inherited method is hidden by "procedure Equals(TKGridAxisItem):Boolean;"
kgrids.pas(2183,78) Warning: Symbol "CM_SYSCOLORCHANGE" is not implemented
kgrids.pas(2980,15) Warning: An inherited method is hidden by "procedure ScrollBy(LongInt;LongInt);"
kgrids.pas(5633,14) Warning: range check error while evaluating constants (-2147483640 must be between 0 and 4294967295)
Compiling .\source\khexeditor.pas
khexeditor.pas(780,78) Warning: Symbol "CM_SYSCOLORCHANGE" is not implemented
khexeditor.pas(927,15) Warning: An inherited method is hidden by "procedure ScrollBy(LongInt;LongInt;Boolean);"
khexeditor.pas(4902,27) Warning: Symbol "Handle" is deprecated
?"?????'????? "?????????>???Ő?? ?????'?? pl_KControls 1.3" ??????????????
TProjectResources.Regenerate Save failed
TLazBuildApplication.BuildProject Project1.Resources.Regenerate failed
TPkgManager.CheckCompileNeedDueToDependencies  State file of pl_KControls 1.3 is newer than state file of ?????????': cthexeditor
sqldblaz.pas(10,25) Hint: Unit "SQLStringsPropertyEditorDlg" not used in SQLDBLaz
1955 lines compiled, 0.8 sec
19 hint(s) issued
?"?????'????? "?????????>???Ő?? ?????'?? SQLDBLaz 1.0.1" ??????????????
TPkgManager.CheckCompileNeedDueToDependencies  State file of lazdbexport 1.0 is newer than state file of ?????????': lazdatadesktop
44 hint(s) issued
?"?????'????? "?????????>???Ő?? ?????'?? lazdatadict 0.0" ??????????????
TLazPackageGraph.CheckIfCurPkgOutDirNeedsCompile  Compiler custom params changed for SQLDBLaz 1.0.1
[TCompiler.Compile] end
primary config path: C:\Users\bdv\AppData\Roaming\lazarus64
TPkgManager.CheckCompileNeedDueToDependencies  State file of LCL 1.0.1 is newer than state file of ?????????': ctresbuilder
[INFO]: Move Executables
C:\codetyphon\lazarus\lazarus.exe
C:\codetyphon\lazarus\lazbuild.exe
C:\codetyphon\lazarus\startlazarus.exe
?६?饭? 䠩?:         3.
C:\codetyphon\lazarus\tools\lazres.exe
C:\codetyphon\lazarus\tools\lrstolfm.exe
C:\codetyphon\lazarus\tools\svn2revisioninc.exe
C:\codetyphon\lazarus\tools\updatepofiles.exe
?६?饭? 䠩?:         4.
C:\codetyphon\lazarus\components\chmhelp\lhelp\lhelp.exe
?६?饭? 䠩?:         1.
C:\codetyphon\lazarus\tools\lazdatadesktop\lazdatadesktop.exe
?६?饭? 䠩?:         1.
C:\codetyphon\lazarus\tools\ctapimatrix\ctapimatrix.exe
?६?饭? 䠩?:         1.
C:\codetyphon\lazarus\tools\ctdiagramins\ctdiagramins.exe
?६?饭? 䠩?:         1.
C:\codetyphon\lazarus\tools\cthexeditor\cthexeditor.exe
?६?饭? 䠩?:         1.
C:\codetyphon\lazarus\tools\ctimgviewer\ctimgviewer.exe
?६?饭? 䠩?:         1.
C:\codetyphon\lazarus\tools\ctresbuilder\ctresbuilder.exe
?६?饭? 䠩?:         1.
??஢? 䠩?:         1.
Last edit: by Arioch.
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3218
  • Arioch
And some suboptimal signs below, in separate post
Compiling fcllaz.pas
fcllaz.pas(10,16) Hint: Unit "db" not used in fcllaz
fcllaz.pas(10,20) Hint: Unit "process" not used in fcllaz
fcllaz.pas(10,29) Hint: Unit "simpleipc" not used in fcllaz
fcllaz.pas(10,40) Hint: Unit "eventlog" not used in fcllaz
fcllaz.pas(10,50) Hint: Unit "XMLConf" not used in fcllaz
Compiling lazutils.pas
lazutils.pas(10,13) Hint: Unit "Laz2_XMLCfg" not used in LazUtils
lazutils.pas(10,55) Hint: Unit "laz2_XMLWrite" not used in LazUtils
lazutils.pas(10,70) Hint: Unit "Laz_DOM" not used in LazUtils
lazutils.pas(11,3) Hint: Unit "Laz_XMLCfg" not used in LazUtils
lazutils.pas(11,15) Hint: Unit "Laz_XMLRead" not used in LazUtils
lazutils.pas(11,28) Hint: Unit "Laz_XMLStreaming" not used in LazUtils
lazutils.pas(11,46) Hint: Unit "Laz_XMLWrite" not used in LazUtils
lazutils.pas(11,60) Hint: Unit "LazFileUtils" not used in LazUtils
lazutils.pas(12,17) Hint: Unit "LUResStrings" not used in LazUtils
lazutils.pas(12,40) Hint: Unit "LazDbgLog" not used in LazUtils
lazutils.pas(12,51) Hint: Unit "paswstring" not used in LazUtils
lazutils.pas(13,3) Hint: Unit "lazutf8classes" not used in LazUtils
lazutils.pas(13,19) Hint: Unit "Masks" not used in LazUtils
lazutils.pas(13,26) Hint: Unit "LazUtilsStrConsts" not used in LazUtils
lazutils.pas(14,3) Hint: Unit "lazutf8sysutils" not used in LazUtils
lazutils.pas(14,20) Hint: Unit "LazMethodList" not used in LazUtils
lazutils.pas(14,35) Hint: Unit "AvgLvlTree" not used in LazUtils
lazutils.pas(14,58) Hint: Unit "LazFreeType" not used in LazUtils
lazutils.pas(14,71) Hint: Unit "TTCache" not used in LazUtils
lazutils.pas(15,3) Hint: Unit "TTCalc" not used in LazUtils
lazutils.pas(15,11) Hint: Unit "TTCMap" not used in LazUtils
lazutils.pas(15,19) Hint: Unit "TTDebug" not used in LazUtils
lazutils.pas(15,28) Hint: Unit "TTError" not used in LazUtils
lazutils.pas(15,45) Hint: Unit "TTGLoad" not used in LazUtils
lazutils.pas(15,54) Hint: Unit "TTInterp" not used in LazUtils
lazutils.pas(15,64) Hint: Unit "TTLoad" not used in LazUtils
lazutils.pas(16,3) Hint: Unit "TTMemory" not used in LazUtils
lazutils.pas(16,13) Hint: Unit "TTObjs" not used in LazUtils
lazutils.pas(16,21) Hint: Unit "TTProfile" not used in LazUtils
lazutils.pas(16,32) Hint: Unit "TTRASTER" not used in LazUtils
lazutils.pas(16,42) Hint: Unit "TTTables" not used in LazUtils
lazutils.pas(16,52) Hint: Unit "TTTypes" not used in LazUtils
lazutils.pas(17,34) Hint: Unit "LazClasses" not used in LazUtils
allsynedit.pas(10,3) Hint: Unit "SynBeautifier" not used in allsynedit
allsynedit.pas(10,42) Hint: Unit "SynEditAutoComplete" not used in allsynedit
allsynedit.pas(10,63) Hint: Unit "SynEditExport" not used in allsynedit
allsynedit.pas(12,3) Hint: Unit "SynEditHighlighterXMLBase" not used in allsynedit
allsynedit.pas(12,46) Hint: Unit "LazSynEditMouseCmdsTypes" not used in allsynedit
allsynedit.pas(13,3) Hint: Unit "SynEditLines" not used in allsynedit
allsynedit.pas(13,17) Hint: Unit "SynEditMarks" not used in allsynedit
allsynedit.pas(13,31) Hint: Unit "SynEditMarkup" not used in allsynedit
allsynedit.pas(13,46) Hint: Unit "SynEditMarkupBracket" not used in allsynedit
allsynedit.pas(14,3) Hint: Unit "SynEditMarkupCtrlMouseLink" not used in allsynedit
allsynedit.pas(14,31) Hint: Unit "SynEditMarkupHighAll" not used in allsynedit
allsynedit.pas(14,53) Hint: Unit "SynEditMarkupSelection" not used in allsynedit
allsynedit.pas(15,3) Hint: Unit "SynEditMarkupSpecialLine" not used in allsynedit
allsynedit.pas(15,29) Hint: Unit "SynEditMarkupWordGroup" not used in allsynedit
allsynedit.pas(15,53) Hint: Unit "SynEditMiscClasses" not used in allsynedit
allsynedit.pas(15,73) Hint: Unit "SynEditMiscProcs" not used in allsynedit
allsynedit.pas(16,21) Hint: Unit "SynEditPlugins" not used in allsynedit
allsynedit.pas(16,37) Hint: Unit "SynEditPointClasses" not used in allsynedit
allsynedit.pas(16,58) Hint: Unit "SynEditRegexSearch" not used in allsynedit
allsynedit.pas(17,3) Hint: Unit "SynEditStrConst" not used in allsynedit
allsynedit.pas(17,20) Hint: Unit "SynEditTextBase" not used in allsynedit
allsynedit.pas(17,37) Hint: Unit "SynEditTextBuffer" not used in allsynedit
allsynedit.pas(17,56) Hint: Unit "SynEditTextBidiChars" not used in allsynedit
allsynedit.pas(18,3) Hint: Unit "SynEditTextTabExpander" not used in allsynedit
allsynedit.pas(18,27) Hint: Unit "SynEditTextTrimmer" not used in allsynedit
allsynedit.pas(18,47) Hint: Unit "SynEditTypes" not used in allsynedit
allsynedit.pas(18,61) Hint: Unit "SynExportHTML" not used in allsynedit
allsynedit.pas(18,76) Hint: Unit "SynGutter" not used in allsynedit
allsynedit.pas(19,3) Hint: Unit "SynGutterBase" not used in allsynedit
allsynedit.pas(19,18) Hint: Unit "SynGutterChanges" not used in allsynedit
allsynedit.pas(19,58) Hint: Unit "SynGutterLineNumber" not used in allsynedit
allsynedit.pas(20,3) Hint: Unit "SynGutterLineOverview" not used in allsynedit
allsynedit.pas(20,26) Hint: Unit "SynGutterMarks" not used in allsynedit
allsynedit.pas(21,42) Hint: Unit "SynHighlighterHashEntries" not used in allsynedit
allsynedit.pas(23,61) Hint: Unit "SynHighlighterPosition" not used in allsynedit
allsynedit.pas(25,40) Hint: Unit "SynMacroRecorder" not used in allsynedit
allsynedit.pas(25,58) Hint: Unit "SynMemo" not used in allsynedit
allsynedit.pas(26,3) Hint: Unit "SynPluginSyncronizedEditBase" not used in allsynedit
allsynedit.pas(26,56) Hint: Unit "LazSynEditText" not used in allsynedit
allsynedit.pas(26,72) Hint: Unit "LazSynTextArea" not used in allsynedit
allsynedit.pas(27,30) Hint: Unit "SynEditMarkupGutterMark" not used in allsynedit
allsynedit.pas(28,3) Hint: Unit "SynEditMarkupSpecialChar" not used in allsynedit
allsynedit.pas(28,29) Hint: Unit "SynEditTextDoubleWidthChars" not used in allsynedit
Compiling fpcunitide.pas
fpcunitide.pas(10,22) Hint: Unit "strtestcaseopts" not used in fpcunitide
Compiling projtemplates.pas
projtemplates.pas(10,5) Hint: Unit "ProjectTemplates" not used in ProjTemplates
projtemplates.pas(10,43) Hint: Unit "frmTemplateVariables" not used in ProjTemplates
Compiling leakview.pas
leakview.pas(10,16) Hint: Unit "leakinfo" not used in leakview
leakview.pas(10,26) Hint: Unit "DbgInfoReader" not used in leakview
Compiling memdslaz.pas
memdslaz.pas(10,3) Hint: Unit "memds" not used in MemDSLaz
Compiling sdflaz.pas
sdflaz.pas(10,16) Hint: Unit "SdfData" not used in SDFLaz
Compiling tachartlazaruspkg.pas
tachartlazaruspkg.pas(11,29) Hint: Unit "TASubcomponentsEditor" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(12,3) Hint: Unit "TATypes" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(12,12) Hint: Unit "TADrawUtils" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(13,34) Hint: Unit "TACustomSource" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(13,50) Hint: Unit "TAGeometry" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(14,51) Hint: Unit "TAChartAxisUtils" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(15,19) Hint: Unit "TAEnumerators" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(16,18) Hint: Unit "TAMath" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(16,57) Hint: Unit "TAAnimatedSource" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(17,3) Hint: Unit "TATextElements" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(17,19) Hint: Unit "TAAxisSource" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(17,54) Hint: Unit "TACustomFuncSeries" not used in TAChartLazarusPkg
tachartlazaruspkg.pas(18,3) Hint: Unit "TAFitUtils" not used in TAChartLazarusPkg
Compiling todolistlaz.pas
todolistlaz.pas(10,12) Hint: Unit "TodoList" not used in ToDoListLaz
todolistlaz.pas(10,22) Hint: Unit "ToDoListStrConsts" not used in ToDoListLaz
Compiling jcfidelazarus.pas
jcfidelazarus.pas(12,5) Hint: Unit "JcfIdeMain" not used in jcfidelazarus
jcfidelazarus.pas(12,46) Hint: Unit "BuildParseTree" not used in jcfidelazarus
jcfidelazarus.pas(12,62) Hint: Unit "BuildTokenList" not used in jcfidelazarus
jcfidelazarus.pas(13,3) Hint: Unit "ParseError" not used in jcfidelazarus
jcfidelazarus.pas(13,15) Hint: Unit "ParseTreeNode" not used in jcfidelazarus
jcfidelazarus.pas(13,30) Hint: Unit "ParseTreeNodeType" not used in jcfidelazarus
jcfidelazarus.pas(13,49) Hint: Unit "PreProcessorExpressionParser" not used in jcfidelazarus
jcfidelazarus.pas(14,3) Hint: Unit "PreProcessorExpressionTokenise" not used in jcfidelazarus
jcfidelazarus.pas(15,3) Hint: Unit "PreProcessorParseTree" not used in jcfidelazarus
jcfidelazarus.pas(15,26) Hint: Unit "SourceToken" not used in jcfidelazarus
jcfidelazarus.pas(15,39) Hint: Unit "SourceTokenList" not used in jcfidelazarus
jcfidelazarus.pas(15,64) Hint: Unit "TokenUtils" not used in jcfidelazarus
jcfidelazarus.pas(16,3) Hint: Unit "fShowParseTree" not used in jcfidelazarus
jcfidelazarus.pas(16,19) Hint: Unit "AlignAssign" not used in jcfidelazarus
jcfidelazarus.pas(16,32) Hint: Unit "AlignBase" not used in jcfidelazarus
jcfidelazarus.pas(16,43) Hint: Unit "AlignComment" not used in jcfidelazarus
jcfidelazarus.pas(16,57) Hint: Unit "AlignConst" not used in jcfidelazarus
jcfidelazarus.pas(17,3) Hint: Unit "AlignField" not used in jcfidelazarus
jcfidelazarus.pas(17,15) Hint: Unit "AlignTypedef" not used in jcfidelazarus
jcfidelazarus.pas(17,29) Hint: Unit "AlignVars" not used in jcfidelazarus
jcfidelazarus.pas(17,40) Hint: Unit "AllProcesses" not used in jcfidelazarus
jcfidelazarus.pas(17,54) Hint: Unit "BaseVisitor" not used in jcfidelazarus
jcfidelazarus.pas(18,3) Hint: Unit "Capitalisation" not used in jcfidelazarus
jcfidelazarus.pas(18,19) Hint: Unit "IdentifierCaps" not used in jcfidelazarus
jcfidelazarus.pas(18,35) Hint: Unit "SpecificWordCaps" not used in jcfidelazarus
jcfidelazarus.pas(18,53) Hint: Unit "UnitNameCaps" not used in jcfidelazarus
jcfidelazarus.pas(19,3) Hint: Unit "IndentAsmParam" not used in jcfidelazarus
jcfidelazarus.pas(19,19) Hint: Unit "Indenter" not used in jcfidelazarus
jcfidelazarus.pas(19,29) Hint: Unit "BasicStats" not used in jcfidelazarus
jcfidelazarus.pas(19,41) Hint: Unit "Nesting" not used in jcfidelazarus
jcfidelazarus.pas(19,50) Hint: Unit "FixCase" not used in jcfidelazarus
jcfidelazarus.pas(19,59) Hint: Unit "RebreakLines" not used in jcfidelazarus
jcfidelazarus.pas(20,3) Hint: Unit "ReduceWhiteSpace" not used in jcfidelazarus
jcfidelazarus.pas(20,21) Hint: Unit "RemoveBlankLine" not used in jcfidelazarus
jcfidelazarus.pas(20,38) Hint: Unit "RemoveComment" not used in jcfidelazarus
jcfidelazarus.pas(21,3) Hint: Unit "RemoveConsecutiveWhiteSpace" not used in jcfidelazarus
jcfidelazarus.pas(21,32) Hint: Unit "RemoveReturn" not used in jcfidelazarus
jcfidelazarus.pas(21,46) Hint: Unit "RemoveUnneededWhiteSpace" not used in jcfidelazarus
jcfidelazarus.pas(22,15) Hint: Unit "RemoveEmptyComment" not used in jcfidelazarus
jcfidelazarus.pas(22,35) Hint: Unit "BlockStyles" not used in jcfidelazarus
jcfidelazarus.pas(22,48) Hint: Unit "LongLineBreaker" not used in jcfidelazarus
jcfidelazarus.pas(22,65) Hint: Unit "NoReturnAfter" not used in jcfidelazarus
jcfidelazarus.pas(23,3) Hint: Unit "NoReturnBefore" not used in jcfidelazarus
jcfidelazarus.pas(23,19) Hint: Unit "PropertyOnOneLine" not used in jcfidelazarus
jcfidelazarus.pas(23,38) Hint: Unit "RemoveBlankLinesAfterProcHeader" not used in jcfidelazarus
jcfidelazarus.pas(24,3) Hint: Unit "RemoveBlankLinesInVars" not used in jcfidelazarus
jcfidelazarus.pas(24,27) Hint: Unit "RemoveConsecutiveReturns" not used in jcfidelazarus
jcfidelazarus.pas(24,53) Hint: Unit "RemoveReturnsAfter" not used in jcfidelazarus
jcfidelazarus.pas(25,3) Hint: Unit "RemoveReturnsAfterBegin" not used in jcfidelazarus
jcfidelazarus.pas(25,28) Hint: Unit "RemoveReturnsBeforeEnd" not used in jcfidelazarus
jcfidelazarus.pas(25,52) Hint: Unit "ReturnAfter" not used in jcfidelazarus
jcfidelazarus.pas(25,65) Hint: Unit "ReturnBefore" not used in jcfidelazarus
jcfidelazarus.pas(26,3) Hint: Unit "ReturnChars" not used in jcfidelazarus
jcfidelazarus.pas(26,16) Hint: Unit "ReturnsAfterFinalEnd" not used in jcfidelazarus
jcfidelazarus.pas(26,38) Hint: Unit "MaxSpaces" not used in jcfidelazarus
jcfidelazarus.pas(26,49) Hint: Unit "NoSpaceAfter" not used in jcfidelazarus
jcfidelazarus.pas(26,63) Hint: Unit "NoSpaceBefore" not used in jcfidelazarus
jcfidelazarus.pas(27,3) Hint: Unit "RemoveSpaceAtLineEnd" not used in jcfidelazarus
jcfidelazarus.pas(27,25) Hint: Unit "SingleSpaceAfter" not used in jcfidelazarus
jcfidelazarus.pas(27,43) Hint: Unit "SingleSpaceBefore" not used in jcfidelazarus
jcfidelazarus.pas(27,62) Hint: Unit "SpaceBeforeColon" not used in jcfidelazarus
jcfidelazarus.pas(28,3) Hint: Unit "SpaceToTab" not used in jcfidelazarus
jcfidelazarus.pas(28,15) Hint: Unit "TabToSpace" not used in jcfidelazarus
jcfidelazarus.pas(28,27) Hint: Unit "SwitchableVisitor" not used in jcfidelazarus
jcfidelazarus.pas(28,46) Hint: Unit "AddBeginEnd" not used in jcfidelazarus
jcfidelazarus.pas(29,3) Hint: Unit "AddBlockEndSemicolon" not used in jcfidelazarus
jcfidelazarus.pas(29,25) Hint: Unit "FindReplace" not used in jcfidelazarus
jcfidelazarus.pas(29,38) Hint: Unit "SortUses" not used in jcfidelazarus
jcfidelazarus.pas(29,48) Hint: Unit "SortUsesData" not used in jcfidelazarus
jcfidelazarus.pas(30,3) Hint: Unit "UsesClauseFindReplace" not used in jcfidelazarus
jcfidelazarus.pas(30,26) Hint: Unit "UsesClauseInsert" not used in jcfidelazarus
jcfidelazarus.pas(30,44) Hint: Unit "UsesClauseRemove" not used in jcfidelazarus
jcfidelazarus.pas(30,62) Hint: Unit "TreeWalker" not used in jcfidelazarus
jcfidelazarus.pas(31,3) Hint: Unit "VisitSetNesting" not used in jcfidelazarus
jcfidelazarus.pas(31,20) Hint: Unit "VisitSetXY" not used in jcfidelazarus
jcfidelazarus.pas(31,32) Hint: Unit "VisitStripEmptySpace" not used in jcfidelazarus
jcfidelazarus.pas(31,54) Hint: Unit "WarnAssignToFunctionName" not used in jcfidelazarus
jcfidelazarus.pas(32,3) Hint: Unit "WarnCaseNoElse" not used in jcfidelazarus
jcfidelazarus.pas(32,19) Hint: Unit "WarnDestroy" not used in jcfidelazarus
jcfidelazarus.pas(32,32) Hint: Unit "WarnEmptyBlock" not used in jcfidelazarus
jcfidelazarus.pas(32,48) Hint: Unit "Warning" not used in jcfidelazarus
jcfidelazarus.pas(32,57) Hint: Unit "WarnRealType" not used in jcfidelazarus
jcfidelazarus.pas(33,3) Hint: Unit "WarnUnusedParam" not used in jcfidelazarus
jcfidelazarus.pas(33,20) Hint: Unit "Converter" not used in jcfidelazarus
jcfidelazarus.pas(33,31) Hint: Unit "ConvertTypes" not used in jcfidelazarus
jcfidelazarus.pas(33,45) Hint: Unit "EditorConverter" not used in jcfidelazarus
jcfidelazarus.pas(33,62) Hint: Unit "FileConverter" not used in jcfidelazarus
jcfidelazarus.pas(34,24) Hint: Unit "JcfSetBase" not used in jcfidelazarus
jcfidelazarus.pas(34,49) Hint: Unit "SetAlign" not used in jcfidelazarus
jcfidelazarus.pas(34,59) Hint: Unit "SetAsm" not used in jcfidelazarus
jcfidelazarus.pas(34,67) Hint: Unit "SetCaps" not used in jcfidelazarus
jcfidelazarus.pas(35,3) Hint: Unit "SetClarify" not used in jcfidelazarus
jcfidelazarus.pas(35,15) Hint: Unit "SetComments" not used in jcfidelazarus
jcfidelazarus.pas(35,28) Hint: Unit "SetIndent" not used in jcfidelazarus
jcfidelazarus.pas(35,39) Hint: Unit "SetObfuscate" not used in jcfidelazarus
jcfidelazarus.pas(35,53) Hint: Unit "SetPreProcessor" not used in jcfidelazarus
jcfidelazarus.pas(36,3) Hint: Unit "SetReplace" not used in jcfidelazarus
jcfidelazarus.pas(36,15) Hint: Unit "SetReturns" not used in jcfidelazarus
jcfidelazarus.pas(36,27) Hint: Unit "SetSpaces" not used in jcfidelazarus
jcfidelazarus.pas(36,38) Hint: Unit "SettingsTypes" not used in jcfidelazarus
jcfidelazarus.pas(36,53) Hint: Unit "SetTransform" not used in jcfidelazarus
jcfidelazarus.pas(36,67) Hint: Unit "SetUses" not used in jcfidelazarus
jcfidelazarus.pas(37,3) Hint: Unit "SetWordList" not used in jcfidelazarus
jcfidelazarus.pas(37,16) Hint: Unit "SettingsStream" not used in jcfidelazarus
jcfidelazarus.pas(37,32) Hint: Unit "fJcfErrorDisplay" not used in jcfidelazarus
jcfidelazarus.pas(37,50) Hint: Unit "Delay" not used in jcfidelazarus
jcfidelazarus.pas(37,57) Hint: Unit "IntList" not used in jcfidelazarus
jcfidelazarus.pas(38,3) Hint: Unit "JcfFontSetFunctions" not used in jcfidelazarus
jcfidelazarus.pas(38,24) Hint: Unit "JcfHelp" not used in jcfidelazarus
jcfidelazarus.pas(38,41) Hint: Unit "JcfMiscFunctions" not used in jcfidelazarus
jcfidelazarus.pas(38,59) Hint: Unit "fAbout" not used in jcfidelazarus
jcfidelazarus.pas(39,3) Hint: Unit "JcfVersionConsts" not used in jcfidelazarus
jcfidelazarus.pas(45,3) Hint: Unit "jcfuiconsts" not used in jcfidelazarus
Compiling lhelpcontrolpkg.pas
lhelpcontrolpkg.pas(10,3) Hint: Unit "LHelpControl" not used in lhelpcontrolpkg
Compiling chmhelppkg.pas
chmhelppkg.pas(10,15) Hint: Unit "ChmLangRef" not used in ChmHelpPkg
chmhelppkg.pas(10,27) Hint: Unit "ChmLcl" not used in ChmHelpPkg
chmhelppkg.pas(10,35) Hint: Unit "ChmProg" not used in ChmHelpPkg
... and so on.
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3219
did you remove ver 3.10 before
installation of ver 4.00 ?
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3221
  • Arioch
No. i did UPDATE - that mode is enlisted in menu - so when it fails to function it is bug as well.
If 4.00 cannot be used to update - then there should be no such element in menu.
But since i don't installed extra components but the one i am working on, and except for few hotkeys did not changed config, then i can try it as well.
BTW, what do you think about adding two hotkeys into default Lazarus config.
I 1st met them in GExperts plugin for Delphi and then they were re-implemented in cnWizards. They are really quite useful and in Laz can be made just a part of setup.
So i deleted
c:\Users\bdv\AppData\Roaming\lazarus32\
c:\Users\bdv\AppData\Roaming\lazarus64\
c:\Users\bdv\AppData\Local\lhelp\
c:\Users\bdv\Desktop\CodeTyphon64.lnk
c:\Users\bdv\Desktop\Lazarus32.lnk
c:\Users\bdv\Desktop\Lazarus64.lnk
c:\codetyphon\
Anything more to delete ? Registry entries, whatever ?
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3222
  • Arioch
okay, since no more suggestions, let's think those are all.
I removed the files.
I started installer from n:\CodeTyphonIns by running CMD.exe (command shell) with admin rights.
install.bat did not offered me to update CT and only offered install, which i did
Then in CT Center i chosen to build 64-bit Lazarus Big IDE, like before.
As of now it unpacks FPC sources, which are probably required to build IDE as well
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3223
  • Arioch
despite me selecting BigIDE the log started with line about Small IDE.
Deleting all about building FPC adn extracting sources for IDE, i can see even more charset-related errors
 Lazarus32 Restore Default Settings for Windows
..\bin\settings\i386-win32-win32\slazarus\editoroptions.xml
..\bin\settings\i386-win32-win32\slazarus\environmentoptions.xml
..\bin\settings\i386-win32-win32\slazarus\h2pastool.xml
..\bin\settings\i386-win32-win32\slazarus\inputhistory.xml
..\bin\settings\i386-win32-win32\slazarus\lazarus.dci
..\bin\settings\i386-win32-win32\slazarus\miscellaneousoptions.xml
..\bin\settings\i386-win32-win32\slazarus\packagefiles.xml
??஢? 䠩?: 7.
Same for Win64 settings.
lr_class.pas(1629,55) Warning: Constructing a class "TfrFunctionLibrary" with abstract method "DoFunction"
lr_class.pas(1197,20) Hint: Found abstract method: procedure DoFunction(<TfrFunctionLibrary>;LongInt;Variant;Variant;Variant;var Variant);
Hmm...
A lot of
lr_class.pas(9886,30) Warning: Constructing a class "TfrReportDesigner" with abstract method ****
A lot of the same in UPhysics2D and other libs
still all those charset problems like
Writing Resource String Table file: registersqldb.rst
1955 lines compiled, 1.2 sec
19 hint(s) issued
UpdateBasePoFile saving C:\codetyphon\lazarus\components\sqldb\languages\registersqldb.po
Still that finishing
?६?饭? 䠩?:         3.
?६?饭? 䠩?:         4.
?६?饭? 䠩?:         1.
?६?饭? 䠩?:         1.
?६?饭? 䠩?:         1.
?६?饭? 䠩?:         1.
?६?饭? 䠩?:         1.
?६?饭? 䠩?:         1.
?६?饭? 䠩?:         1.
??஢? 䠩?:         1.
"Package not found" errors seemed to disappear though.
Which hints that "upgrade" route does not work.
Perhaps it should be removed from the installer if so...
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3224
  • Arioch
Well, well, I just launched that IDE... and closed it.
Error
An unhandled exception occurred at $0000000076D6B3CB:
EAccessViolation: Access violation
$0000000076D6B3CB
ОК
Then it starts multiplying.
Basically every time i tried to press okay or every time i switched to another app - in essence every time the top-of-stack error message was loosing focus - it raised one more exception.
Okay, this forum seems to delete attachments.. here it is.
You can see at every iteration the exceptions [1 .. (n-1)] are the same.
Also all the windows but last can be freely moved (so they are not modal???) around or focused in and out.
But any attempt to withdraw focus from topmost erro non-modal windows - results in n+1st exception thrown.
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3226
  • Arioch
IDE 32-bit can't be built. After building FPC and GDB for win32 an attempt to build IDE aborts. Tried twice with the same result.
            Compile Lazarus Win32
C:/codetyphon/fpc/bin/i386-win32/make -C packager/registration
make[1]: Entering directory `C:/codetyphon/lazarus/packager/registration'
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f ../units/i386-win32/fcllaz.ppu
C:/codetyphon/fpc/bin/i386-win32/ppc386.exe -MObjFPC -Scghi -O1 -g -gl -vewnhi -l -Fu. -FE. -FU../units/i386-win32 -di386 fcllaz.pas
Hint: Start of reading config file C:\codetyphon\fpc\bin\i386-win32\fpc.cfg
Hint: End of reading config file C:\codetyphon\fpc\bin\i386-win32\fpc.cfg
Free Pascal Compiler version 2.7.1 [2013/02/03] for i386
Copyright (c) 1993-2012 by Florian Klaempfl and others
Target OS: Win32 for i386
Fatal: Can't find unit system used by fcllaz
Fatal: Compilation aborted
make[1]: Leaving directory `C:/codetyphon/lazarus/packager/registration'
[ERROR]: Lazarus32 Small-IDE NOT Build
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3227
Please Sir
some critical questions:
1) Did you full remove old CodeTyphon version before ver 4.00 installation ?
2) Do you have any other FreePascal or Lazarus Installation on your PC ?
3) Please, post a picture of CTC-"Libraries" Page
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3230
  • Arioch
1) i don't know. I deleted the folders mentioned on prev page, but is it full removal or not i cannot say
2) not one my windows box, here i only had CT 2.80 -> 3.10 and now 4.00
3) www.dropbox.com/sh/h4xow5wgpn81g4u/Ta8NX7pVHh/CodeTyphon/CT_400
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3231
  • Arioch
cleaned FPC and rebuilt FPC/win32
then cleaned Laz ans asked to cmopile Laz/Win32 BigIDE
now the situation is weird:
1) Laz/Win32 compilation failed just liek above
2) CTC enlists neither Laz/Win32 nor Laz/Win64 in tools
3) still desktop icon for Lazarus Win64 works
3.1) and it no more crashes on exit
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3232
My suggestion Sir
a) Totally remove directory C:\codetyphon
b) remove all CodeTyphon desktop icons
and reinstall CT ver 4.00
======> 09-Feb-2013 ver 4.00 ===========================================
WARNING: FOR ALL OSes,
we change CodeTyphon directory stucture,
Please, MAKE FULL INSTALL OF CODETYPHON.
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3233
  • Arioch
please look the 1st page!
www.pilotlogic.com/sitejoom/index.php/fo...64?limitstart=0#3221
i removed them and even more.
maybe compilation from CTC script and install.bat are different things and use different make-srcipts?
i still think your installer is broken if it suggests to update 3.10 while it shuld not be allwoed
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3234
So
reinstall-rebuild ALL with CTCenter
and post here the total building log from Commandbox CTC page
save as txt, zip and post
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3235
  • Arioch
as of now i do rebuild all via install.bat (previously i selected to start CTC as early as possible and use it for building )
does it save log somewhere?
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3236
No
CTC and setup.bat run the same OS Script: x_CodeTyphon_Remove_Make_ALL.bat
but with CTC you can save (manual) the building log
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3237
  • Arioch
Hmmm... then it would be interesting to see if that corrupt output text mentioned above would get fixed (little chance) or corrupt differently (probable)
Anyway, i don't feel like killing the script in between.
I think one way or another there is a problem with search folders settings...
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3238
Please, post the building log file
and let us (4 programmers) to help you...
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3239
  • Arioch
I appreciate your work, but i cannot do only CT test at any given moment. Yesterday i ahd a bit time but not an advice.
To the moment, install.bat in "rebuild all" seems to made everything right.
As requested, i know launched CTC and issued "remove all" command.
Few errors in log when building BigIDE Lazarus w64 13 years 9 months ago #3243
  • Arioch
on save log attempt CTC freezes or crashes...
dl.dropbox.com/u/6779577/CodeTyphon/CT_4...build_win7x64_log.7z
