xPL - Project (home automation technologies) 14 years 3 months ago #2247
  • acoliveira
  • acoliveira's Avatar Topic Author
:) Sir sternas,
Can You Integrate with this project? see "xplproject.org.uk" and
"xplproject.googlecode.com/svn/"
FYI:
Cool, my answers below
2012/6/18 Antonio Carlos Oliveira <This email address is being protected from spambots. You need JavaScript enabled to view it.>
Ok, lets go!
- 1) I do not search sup_object.lpk inside xplproject.googlecode.com/svn/lazarus/
Superobject can be downloaded here :http://www.progdigy.com/?page_id=6
Just created a package in order to access all units. You can just add superobject units path to your project and remove reference to sup-object.lpk
- 2) I change something in compile_all.bat “-FiC:\lazarus\components\....” to “-FiC:\codetyphon\lazarus\components\....” and “-FuC:\pp\packages\fcl-base\src” to “-FuC:\codetyphon\fpcsrc\packages\fcl-base\src”, because codetyphon suite.
Yes, if you don't use codetyphon, you will have to change some directories and packages. Do you use Lazarus or Delphi ?
- 3) I do not search too “-Fu..\..\..\components\superobjectv1.2.4” and others.
Same as above.
Oh, i´m a Brazilian guy, and my English is horrible too, but…
ac
Enviada em: segunda-feira, 18 de junho de 2012 17:02
Para: Antonio Carlos Oliveira
Assunto: Re: ENC: Lazarus Library
Yes, for sure ! As I am a french guy my english is probably not far better :) how can I help ?
Le 18 juin 2012 21:54, "Antonio Carlos Oliveira" <This email address is being protected from spambots. You need JavaScript enabled to view it.> a écrit :
Sorry for my poor english, can you help me?
Best regards
Antonio carlos,
De: Soitjes Soit
Enviada em: segunda-feira, 18 de junho de 2012 15:53
Assunto: Re: Lazarus Library
Hello Antonio,
The Lazarus xpl library can be found here : code.google.com/p/xplproject/source/browse/#svn%2Flazarus
You will also find some examples that get you going. I use a special version of this library that is compatible with Delphi.
Good luck,
Soitjes.
Sorry for my poor english, im a newbee and start study xpl specification&projects, but I do not found Lazarus Xpl library(sup_object) too, can help me.
Best regards,
xPL - Project (home automation technologies) 14 years 3 months ago #2248
we will test this big package
and we will report here
xPL - Project (home automation technologies) 14 years 3 months ago #2249
  • glhopital
  • glhopital's Avatar
Hello, I'm the developer of the xPL Lazarus Library and will be glad to help if needed. Could you please suppress email addresses from the first post of this topic ?
xPL - Project (home automation technologies) 14 years 3 months ago #2260
  • Chris
  • Chris's Avatar
  • Thank you received: 4
Hi Sternas
just flagging this as I think you might have missed the request from the xPL developer to supress the email addresses from the original post at the start of this thread.
Chris
EDIT: ignore this I see the original poster removed the developers email address but not his own.
Last edit: by Chris. Reason: update
xPL - Project (home automation technologies) 13 years 4 months ago #4232
  • acoliveira
Sir Sternas, do you have any news?
xPL - Project (home automation technologies) 13 years 4 months ago #4233
No yet Sir
