Help integration planned? 14 years 4 months ago #2239
  • avra
  • avra's Avatar Topic Author
Is there a plan to integrate F1 help in Lazarus CodeTyphon edition in the near future? I prefer CHM but HTML would be fine too.
Last edit: by avra.
Help integration planned? 14 years 3 months ago #2252
  • draughlin
  • draughlin's Avatar
I just wanted to say thanks for the great work you have done so far in CodeTyphon. I have it installed under Win 7 x64, Win XP x86, Ubuntu 12.04LTS x64, FreeBSD 9.0 x64 and am looking forward to the Mac OSX QT4 based availability when it is ready. It is exactly what I needed for some cross platform development.
I would just like to echo avra's question, on the availability of integrated help from the Lazarus IDE. I have downloaded pre-compiled CHM's and HTML and placed the CHM's in the codetyphon\lazarus\docs\chm directory and extracted the HTML archive into the codetyphon\lazarus\docs\html directory but still no luck in highlighting a keyword and pressing F1. An error dialogue box appears with the message that "Help keyword 'FPCKeyword_keyword' not found." The dialogue box title is incomplete but reads "A help database was found for this topic, but this topic w..."
I also built the "build_lcl_docs.exe", modified the build_chm.bat and build_html.bat to point to the fpc compiler directory and still no luck.
Any help in this regard in the future would be appreciated and please, keep up the good work. :cheer:
Help integration planned? 14 years 3 months ago #2254
we will check this
Help integration planned? 14 years 3 months ago #2395
  • avra
fpcup automates adding CHM documentation and configuring the Lazarus help. Maybe sources can be helpful.
bitbucket.org/reiniero/fpcup/overview
Help integration planned? 14 years 3 months ago #2397
Yes Sir
we working on this
Screen from Linux64
and big image
The following user(s) said Thank You: Konstantinos Papadoulas, avra, draughlin, Pierre Joubert
