PPU Source: graphics.pp not found error 14 years 5 months ago #2082
  • Bernd Klingesberger
  • Bernd Klingesberger's Avatar Topic Author
I do have installed the CodeTyphon on Win 7 x86_64 and I'm using the Graphics unit in my library project. I do have searched for the graphics.pp file but I coouldn't find it. What can I do to implement the graphics.pp file.
Re: PPU Source: graphics.pp not found error 14 years 5 months ago #2083
  • Chris
  • Chris's Avatar
  • Thank you received: 4
Hi pegasus0211
it should be in the folder
c:\codetyphon\lazarus\lcl
you shouldn't need to create it.
If you just try and create a new project (from the Project Menu) and choose "Application" it should create a new project with the following "uses" clause on the default unit that's created;
uses
Classes, SysUtils, FileUtil, Forms, Controls, Graphics, Dialogs;
By default the project will also include the "LCL" in the required packages (the "Graphics" unit is part of this package as are all the other units above - other units may be in other packages) - and the source is in the "c:\codetyphon\lazarus\lcl" folder.
If you're trying to convert a Delphi application then you might need to add the LCL package as a "new requirement" in the Project Inspector.
TheBlackSheep
Re: PPU Source: graphics.pp not found error 14 years 5 months ago #2087
Thx for your tip. Now it's working.
