A couple of Components to include in CT? 14 years 6 months ago #1849
  • Curt
  • Curt's Avatar Topic Author
I have a couple of components which I use at times. They are not mine but I do find them usefull.
History Files. While somewhat like a MRU type system this is very easy to use and works great. In fact I had it installed
in CT 2.50 Laz but seems like 2.60 Laz doesn't like it. Set the package up for installation, rebuild, Restart....nada.
Maybe it could be included in an upcoming release.
Download link:
sourceforge.net/projects/lazarus-ccr/fil...s-1.2.1.zip/download
As above this one I had in 2.50 but not in 2.60. (Probably my error)
UniqueInstance. Allows only on instance of an application to run at one time.
Download link:
code.google.com/p/luipack/
Thanks,
Curt
Re: A couple of Components to include in CT? 14 years 6 months ago #1850
We will add THistoryFiles comp to next release
For UniqueInstance, we must make some test first.
Re: A couple of Components to include in CT? 14 years 6 months ago #1882
  • Javier Lorenzo
  • Javier Lorenzo's Avatar
I am already using UniqueInstance with CodeTyphon, it will be very useful if it comes installed in the new versions. Now I have to download/compile/install separately with every new release.
