CT 2.40 problems with databases 14 years 8 months ago #1635
  • Maximiliano
  • Maximiliano's Avatar Topic Author
Since I go to CT 2.40, Zeos stopped working, and sqlquery not insert / modify / delete records in the database.
This does not happen in standard versions of lazarus.
I found comments that it is a compilation error.
Desde que me pase a CT 2.40, dejó de funcionar zeos, y sqlquery no inserta/modifica/borra registros en la base de datos.
Esto no ocurre en las versiones estandares de lazarus.
Encontre comentarios, de que es un error en la compilación
Re: CT 2.40 problems with databases 14 years 8 months ago #1695
  • Javier Lorenzo
  • Javier Lorenzo's Avatar
The same has happened to me, new version 2.50 seems to solve the problem, at least it has worked for me! :woohoo:
Lo mismo me ocurrió a mí, la versión 2.50 parece haber resuelto el problema, al menos para mí! :woohoo:
