Educational project with minimal distribution 17 years 8 months ago #13
  • Paul Breneman
  • Paul Breneman's Avatar Topic Author
Very interesting distribution. I recently released the opposite type of distribution - the minimal files needed to compile several simple example programs using FreePascal.
Environment Monitoring Programs
Information and example programs for an educational programming project
www.turbocontrol.com/monitor.htm
Today I installed the latest 0.888 (Beta) CodeTyphon on a fresh install of the new Debian 5.0 LXDE OS.
Regards,
Paul Breneman
www.TurboControl.com
www.TurboControl.com/TPSupport.htm - TurboPower support links
Re:Educational project with minimal distribution 17 years 8 months ago #14
Thanks Sir.
Re:Educational project with minimal distribution 17 years 7 months ago #21
  • Paul Breneman
Thanks for adding Debian LXDE support! Yesterday I did a fresh install of Debian LXDE. Using the 150 MB NetInstall CD (and not installing OO and GIMP) the install only takes about one-half hour and only uses 860 MB of the disk.
Since Debian is used in a lot of embedded projects the LXDE distro seems to be a nice lean distro to use for simple testing. I hope to write up a page about this for my educational project.
I installed the latest CodeTyphon 0.899 Beta into the fresh LXDE and that went very well.
ARM processors seem to be more popular all of the time so if you added ARM-Linux support that might be useful.
Re:Educational project with minimal distribution 17 years 7 months ago #22
Please wait for next ver 0.900
Cross-arm-linux element is working ok
Look at attach pic
Thanks again.
