TcyFieldLink update 2 months 4 hours ago #19673
  • Nicola
  • Nicola's Avatar Topic Author
File Name: cyFieldLink.7z
File Size:3 KB
Hello,I knew the Cindy components from Delphi, and in the past I used TcyFieldLink in particular. I wanted to use it in one of my CodeTyphon projects by linking it to the Text property of the TEditButton component, but nothing happened.After going back over the code, I made some changes and now it works perfectly. I wanted to share it with you. I'm attaching the updated cyFieldLink.pas file. I hope it will be useful.   Thank you for the great work you've done with CT.
TcyFieldLink update 2 months 4 hours ago #19674
We will add your code to LAB CT
