Components and Libraries for Documents Development, discussions, problems and suggestions
CT not has pdfviewer 1 year 8 months ago #18836
  • Fernando Sandoval
Hello ct not has pdfviewer component...
i need some component to open pdf file and view...
CT not has pdfviewer 1 year 8 months ago #18837
  • LuZZZZi
  • LuZZZZi's Avatar
Hi Fernando.
you can try this Git stuff github.com/dinmil/PDFPreview or lz_Report, lz_fpReport.
Cheers
CT not has pdfviewer 1 year 8 months ago #18838
  • Fernando Sandoval
Yes i download the component but send this error when i compile pdfviewer
winprinterutils.pas(230,130) Error: Call by var for arg no. 7 has to match exactly: Got "LongWord" expected "QWord"
CT not has pdfviewer 1 year 8 months ago #18839
  • Fernando Sandoval
Are you sure is for ct ?..............
CT not has pdfviewer 1 year 8 months ago #18844
  • LuZZZZi
  • LuZZZZi's Avatar
Try QWord(@Variable) or try to change the variable in the derfinition part to QWord
Last edit: by LuZZZZi.
CT not has pdfviewer 1 year 8 months ago #18845
  • Fernando Sandoval
I tested on ct 32 bits works  fine , but i think need changes for 64 bits,,,
CT not has pdfviewer 1 year 8 months ago #18877
  • Fernando Sandoval
Lu thanks i tried to make changes but i don't understand exactly where i need change... here is where i trie to do..
on ascdef.inc thsi the line
function SendMessageTimeout(Qword(@hWnd:HWND); Msg:UINT; wParam:WPARAM; lParam:LPARAM; fuFlags:UINT;uTimeout:UINT; lpdwResult:PDWORD_PTR):LRESULT; external 'user32' name 'SendMessageTimeoutA';
and this on redef.inc
function SendMessageTimeout(hWnd: Qword(@HWND); Msg: UINT; wParam: WPARAM; lParam: LPARAM; fuFlags, uTimeout: UINT; var lpdwResult: DWORD_PTR): LRESULT;external 'user32' name 'SendMessageTimeoutA';
here is the line where send errror
SendMessageTimeout(HWND_BROADCAST, WM_DEVMODECHANGE, 0, LPARAM(pchar(InPrinterName)), SMTO_NORMAL, 1000, MyDWNeeded);
can guide me lite more to make changes for 64 bits compile...
why i need is because i start app with pdf and connect to mysql but i have problem communicate mysql 32 app to 64 bits server  whe load library send error.  can load the library..
for i need compile pdviewer on 64 bits...
