Components and Libraries for Documents Development, discussions, problems and suggestions
FP Spreadsheet Reader not found for file 8 years 6 months ago #11648
  • universe
I noticed the exception of "Reader not found for file (xlsx)" while using latest CT6.4 on Windows, the problem lays in the file fpspreadsheetctrls.pas as earlier version (CT6.0) used to have fpsAllFormats but commented out
unit fpspreadsheetctrls;
{$mode objfpc}{$H+}
interface
uses
  Classes, Graphics, SysUtils, Controls, StdCtrls, ComCtrls, ValEdit, ActnList,
  LResources, LCLVersion,
  fpstypes, fpspreadsheet; //, {%H-}fpsAllFormats;
Is this a bug?
So I added it back and the problem solved.
Thanks in advance.
FP Spreadsheet Reader not found for file 8 years 6 months ago #11649
Yes this is one solution
the other is to
add fpsAllFormats.pas in your project "uses" session
