CT3.0 + SQLITE + help 13 years 10 months ago #2843
  • Johan
  • Johan's Avatar Topic Author
Hi all,
Seems that I get access violiatins errors when I perform following.
Create form, add zeosconnection to form, configure zeosconnections to local DB + protocol Sqlite3.1
When I now set connection to true in the ide, I get an access violation.
I also have this when using the sqliteconnection.
Can somebody tell me how to retrieve the error via a logfile, since only thing I see is this "access violation"
Thanks in advace.
CT3.0 + SQLITE + help 13 years 9 months ago #2865
  • mtbf40
  • mtbf40's Avatar
please post the code...
CT3.0 + SQLITE + help 13 years 9 months ago #2869
  • Johan
Hi thanks for your intrest but the problem has been solved, seems that I had 2 versions of sqlite.dll file after copying new version, no more errors.
