Tools, Runtimes binaries, Toolchains, OS Scripts and OS Libraries, discussions, problems and suggestion
Toolchains builder for android 11 years 1 month ago #8354
  • Leslie
  • Leslie's Avatar Topic Author
  • Thank you received: 4
I have updated tthe fpc source from SVN. (There were some android related changes.)
After rebuilding the compiler rebuilding the toolchain for android arm had some problem.
See the attached files.
Sysinfo:
Windows 10
Typhon 5.50 32bit IDE
Cheers,
Leslie
Toolchains builder for android 11 years 1 month ago #8373
Android use "Custom Toolchains", provided with the Android NDK info .
We package these Android "Custom Toolchains" to our Web Server "toolchains" directory
and you can download these Android Custom Toolchains from CTCenter => "Toolchains Download" Dialog
If you want, you can make your own Android "Custom Toolchain".
In this case, you must develop a new "Cross Binutils" script like x_Cross_Binutils_arm_android.sh in C:\codetyphon\ScriptsWin\crossbuild folder
This is "Guru" Development Level... :dry:
Toolchains builder for android 11 years 1 month ago #8374
  • Leslie
Thank you!
Toolchains builder for android 8 years 8 months ago #11420
  • Pedro
  • Pedro's Avatar
regards
I am new to CodeTyphon since I develop in Embarcadero Rad Studio, I have been configuring CodeTyphon and I have not been able to activate it to develop in Android or IOs, I apologize for my ignorance I have not already been all the steps it says but that option is never activated.
I hope you help me please.
Last edit: by Pedro.
Toolchains builder for android 8 years 8 months ago #11422
Please, read this tutorial
Toolchains builder for android 8 years 8 months ago #11522
  • Pedro
  • Pedro's Avatar
Greetings, sorry again .. but I do it and it does not work for me at all
Toolchains builder for android 8 years 8 months ago #11523
please, give us more info
and first the basics
-Your OS
-Your CT version
-What do you want to do with CT
-Where did you find a problem
-etc
Toolchains builder for android 8 years 7 months ago #11565
  • Pedro
  • Pedro's Avatar
Greetings.
I work more Linux64 or Windows64. I do all the steps indicated by the web site .. but I do not see the APK .. it is not like RAD that you can connect the Team and work directly from the team.
When I work CP 64bit nothing works for me I have to do it in CP 32bit I have no problem working on 32bit.
CP .: If I created the APK I do not have any problem and work it that way ... but it does not work for me in any way it does not generate anything but a file with a blank extension. As I say I do everything and compile but it does not work ..
Download version 6.40 and I do not see any strength on Android either.
Maybe it's my ignorance that I'm missing a step ... but I do it indentico.
I use Lazarus and the library works for me (lazandroidmodulewizard-master) but I do not want Lazarus.
Please I need help or a video to see how I configure it in another way. please.
Toolchains builder for android 8 years 7 months ago #11568
CodeTyphon stop on native Android app building.
We don't add build Android APK file functionality to CT yet
Please, search to Internet for more
