ARM cross-compiling 17 years 1 month ago #115
  • Kjow
  • Kjow's Avatar Topic Author
Hi all,
I have a pair of problems with ARM cross-compiling.
Common steps:
I install CodeTyphon on Win7,
I build all cross for FPC32, then for Laz32
I launch Laz32 and I make simple program.
then:
1) arm-linux from Windows (7)
While compiling I get error: "cannot find -lX11"
2) arw-wince from Windows (7)
Simple program build OK, but if I use GLScene it give me error: "bad option -Rintel"
If I remove all glscene components it give me same error.
I can use GLScene for arm cpus?
thanks!
Re:ARM cross-compiling 17 years 1 month ago #116
Please read CodeTyphon Web Help,
cross_build_for_wince
for details.
Re:ARM cross-compiling 17 years 1 month ago #117
  • Kjow
Thank's but... what you posted is the only one that worked for me, the only thing that I not asked :)
Re:ARM cross-compiling 16 years 11 months ago #150
  • Kjow
Hi, i can't get working arm-linux build.
In your specs there is:
Win32 Layer is Cross-Build Center with Cross Elements for:
o arm-Wince
o arm-Linux
o etc...
But arm-Linux doesn't build. Everytime is error: "cannot find -lX11".
Can you tell me why?
Thank you!
Re:ARM cross-compiling 16 years 11 months ago #151
  • AlerMeta
  • AlerMeta's Avatar
I install the latest version (0.994)
- FPC build 32bit - ok
- Lazarus build 32bit - ok
- lazarus32 build Cross elements arm-wince - error:
ERROR: lazarus\lcl\units\arm-wince\ NOT Exists
Sorry, Lazarus32 arm-wince Element NOT Build
Why? Please help.
Thx.
Re:ARM cross-compiling 16 years 11 months ago #152
  • AlerMeta
  • AlerMeta's Avatar
Sorry:
Try compiling (arm-wince):
project1.lpr(6,28) Fatal: Can't find unit Interfaces used by Project1
