Converting Delphi4 code 3 years 2 months ago #17982
  • W. Peterson
  • W. Peterson 's Avatar Topic Author
1. Trying to convert an old Delphi4 program.  The compiler doesn't recognize GetWindowDC (GetDesktopWindow);
var R : TRect; DeskTop : TCanvas;
     with DeskTop do
          Handle := GetWindowDC (GetDesktopWindow);
2. Compiler doesn't recognize these marked with -->:
procedure TForm2.Image1MouseDown(Sender: TObject; Button: TMouseButton;
  Shift: TShiftState; X, Y: Integer);
   ProcessID : DWORD;
   ProcessHandle : THandle;
   ThreadHandle : THandle;
//set highest priority
-->   ProcessID := GetCurrentProcessID;
-->   ProcessHandle := OpenProcess(PROCESS_SET_INFORMATION, false, ProcessID);
-->   SetPriorityClass(ProcessHandle, REALTIME_PRIORITY_CLASS);
-->   ThreadHandle := GetCurrentThread;
-->   SetThreadPriority(ThreadHandle, THREAD_PRIORITY_TIME_CRITICAL);
Thanks for any help.
Converting Delphi4 code 3 years 2 months ago #17983
Did you add to the Uses section "Windows" unit ?
Converting Delphi4 code 3 years 2 months ago #17984
  • W. Peterson
Yes, Windows is in the units section.
Converting Delphi4 code 3 years 2 months ago #17985
Please, any sample project for tests ?
Converting Delphi4 code 3 years 2 months ago #17993
  • W. Peterson
This thing is huge.  Probably not worth it.  Thanks.  By the way, I travel and can't get back quickly.
