Using blowfish encryption 4 years 3 weeks ago #17352
  • Robert Jenkins
  • Robert Jenkins's Avatar Topic Author
When I use blowfish to encrypt / decrypt a stream, the stream will increase in size up a size evenly divisible by 8 when encrypted.  When decrypted, the result is padded with null characters.
I did some tests and generated some streams of random data and then encrypted and decrypted.
Windows 11 x64.  CT 7.9 - Attached a demo program to show exactly what I am doing.
  0.  InSize:4095, BlowSize:4096, OutSize:4096, InHash: 657DF591BDFED94A82EF7819EE852CE0, OutHash: 7520CC2C1A5CFE304072C90FDF159327 - Match: False
  1.  InSize:4096, BlowSize:4096, OutSize:4096, InHash: 9C750B9E40FAF2D84D652EE50DDD9C59, OutHash: 9C750B9E40FAF2D84D652EE50DDD9C59 - Match: True
  2.  InSize:4097, BlowSize:4104, OutSize:4104, InHash: 98306DE5BE44168AF915BE2A5AFF39F5, OutHash: 3CDEE16FF4B2A22DBC9AC8DA1E9F5EFA - Match: False
  3.  InSize:4098, BlowSize:4104, OutSize:4104, InHash: DFCF511C61EE9720970D6BB4A978FEEE, OutHash: 13F485B1CDFD8E00E6659BC616EDCBEF - Match: False
  4.  InSize:4099, BlowSize:4104, OutSize:4104, InHash: 94BD54877F54036A2787DD53F51E6023, OutHash: C220473A50C9E1C396FEF2104186AF89 - Match: False
  5.  InSize:4100, BlowSize:4104, OutSize:4104, InHash: 5054B6D9796CA07CAF693DE78AC0BE77, OutHash: 18C76E0C3C40EFA790EB9DC854AEAB16 - Match: False
  6.  InSize:4101, BlowSize:4104, OutSize:4104, InHash: DC9E3653DFAC055F2E1D08C203C8D40D, OutHash: A0011E58C042053D064D9399A4DF8390 - Match: False
  7.  InSize:4102, BlowSize:4104, OutSize:4104, InHash: 47647827FAD5651D7996F9364C3F31E3, OutHash: C39EBA1459F8C79B085A42F186541AF8 - Match: False
  8.  InSize:4103, BlowSize:4104, OutSize:4104, InHash: D1F2F6AF89F09DE498E322E96855778B, OutHash: E5E0A99680AFCCBC2AB877E60E02BB5D - Match: False
  9.  InSize:4104, BlowSize:4104, OutSize:4104, InHash: 2BCE1ED95D7306ACC866143B59B14DE7, OutHash: 2BCE1ED95D7306ACC866143B59B14DE7 - Match: True
Here is my code:
{  Uses BlowFish; }
Function BlowFishEncrypt(Const AClearStream: TStream; Const ABlowStream: TStream; Const APassword: String; Const ABufferSize: DWord): Boolean;
Var
  ABlowFish: TBlowFishEncryptStream;
  ABuffer: TBytes;
  ABytesRead: Integer;
Begin
  Result := True;
  AClearStream.Position := 0;
  ABlowStream.Position := 0;
  Try
    ABlowFish := TBlowFishEncryptStream.Create(APassword, ABlowStream);
    Try
      SetLength(ABuffer, ABufferSize);
      Try
        FillChar(ABuffer[0], ABufferSize, 0);
        Repeat
          // Read clear data from clear stream
          ABytesRead := AClearStream.Read(ABuffer, ABufferSize);
          // Write encrypted data to BlowFish stream
          ABlowFish.Write(ABuffer, ABytesRead);
        Until (ABytesRead < ABufferSize);
      Finally
        FillChar(ABuffer[0], Length(ABuffer), 0);
        SetLength(ABuffer, 0);
      End;
    Finally
      FreeAndNil(ABlowFish);
    End;
  Except
    Result := False;
  End;
End;
{  Uses BlowFish; }
Function BlowFishDecrypt(Const ABlowStream: TStream; Const AClearStream: TStream; Const APassword: String; Const ABufferSize: DWord): Boolean;
Var
  ABlowFish: TBlowFishDeCryptStream;
  ABuffer: TBytes;
Begin
  Result := True;
  Try
    ABlowFish := TBlowFishDeCryptStream.Create(APassword, ABlowStream);
    Try
      Try
        Repeat
          // Read encrypted data from BlowFish stream
          ABytesRead := ABlowFish.Read(ABuffer, ABufferSize);
          // write clear data to clear stream
          AClearStream.Write(ABuffer, ABytesRead);
      Finally
      End;
    Finally
    End;
    // AClearStream.Size := AClearStream.Size - 2;
  Except
    Result := False;
  End;
End;
Using blowfish encryption 4 years 2 weeks ago #17373
  • Robert Jenkins
I found a work around.  To encrypt first write the size of the clear stream into the encrypted stream.  To decrypt, first read the size from the encrypted stream and upon decryption, set the clear stream to the size you stored when you encrypted the stream.
{  Uses BlowFish; }
Var
  ABuffer: TBytes;
Begin
  Result := True;
  ABlowStream.WriteData(AClearStream.Size);
  Try
    Try
      Try
        Repeat
      Finally
      End;
    Finally
    End;
  Except
    Result := False;
  End;
End;
{  Uses BlowFish; }
Var
  ABuffer: TBytes;
  ASize : Int64;
Begin
  Result := True;
  ABlowStream.ReadData(ASize);
  Try
    Try
      Try
        Repeat
      Finally
      End;
    Finally
    End;
    If (AClearStream.Size > ASize) Then
    Begin
      AClearStream.Size := ASize;
    End;
  Except
    Result := False;
  End;
End;
Using blowfish encryption 4 years 2 weeks ago #17374
