An error occurred while compiling. whatis the problem and how to solve it? 4 years 5 months ago #17067
  • Brues
  • Brues's Avatar Topic Author
Messages, Errors: 1
Error: There are two units with the same name:
1. "/usr/local/codetyphon/typhon/components/packages_js/js_WebWidgetsGUI/interfaces.pas" from js_WebWidgetsGUI 7.7.1
2. "/usr/local/codetyphon/typhon/lcl/interfaces/cocoa/interfaces.pas" from adLCL 7.7.1
Both packages are connected. This means, either one package uses the other, or they are both used by a third package.
An error occurred while compiling. whatis the problem and how to solve it? 4 years 5 months ago #17068
Read  this
A Pas2JS project you must use only  js_xxxxx packages.
If in your project exists any no js_xxxxx  like adLCL package,
remove it from your project.
LAB CT ver 7.80 has better support to FreePascal Pas2JS source-to-source compiler (S2S Compiler).
The following user(s) said Thank You: Brues
An error occurred while compiling. whatis the problem and how to solve it? 4 years 5 months ago #17071
  • Brues
Thanks.I'll try it.
An error occurred while compiling. whatis the problem and how to solve it? 4 years 5 months ago #17072
  • Brues
@Matis A.
Nice.I've got it.Thank you very much.
