Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 4 months ago #15981
  • Vital
  • Vital's Avatar Topic Author
If TForm has BorderStyle: = bsNone set, then an attempt to make WindowState: = wsMaximized will be ignored by the class.
If this is a bug, is it possible to somehow solve the problem alternatively? For example, it could be like this:
Form.BoundsRect:= Form.Monitor.WorkareaRect;
But!
If more than one monitor is connected, then ...
If maximized on the main monitor, then the window is shifted by the width of the panel beyond the border of the monitor. When maximized on an additional monitor, the window is hidden under the panel itself.
That is, it turns out that you need to calculate the width and position of the panel, and then you can expand the window as needed, subtracting this panel from WorkareaRect.
Question: How do I calculate the width and position of the panel on the desktop?
It should also be borne in mind that there may be several panels. And still wondering how it will be on MacOS, Windows and Linux?
Last edit: by Vital.
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 4 months ago #15990
  • Vital
I can post it to the bug tracker at bugs.freepascal.org. What should I specify in the items: "Product Version" and "Product Build"?
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 4 months ago #15991
  • Vital
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 4 months ago #15992
Good luck Sir
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 1 month ago #16184
  • Vital
Fixed and closed
When will this fix be expected in CT?
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 1 month ago #16185
  • Vital
I'am insert code:
// issue #39158
    if AWinControl.HandleObjectShouldBeVisible and
      (TCustomForm(AWinControl).BorderStyle = bsNone) and
      not Widget.IsMdiChild then
        ConstraintsChange(AWinControl);
in file lcl/interfaces/qt5/qtwsforms.pp, but not working.
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 1 month ago #16186
We don't know,
we must first test this code
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16260
  • Vital
In CT 7.6 not working :(
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16261
Did you try
WindowState := wsFullScreen
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16262
  • Vital
Sorry. Working great!
WindowState:= wsMaximized
Thank you!
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16263
  • Vital
New problem.
If the window is moved to another screen, then maximization stops working. And even if you go back to the previous screen, it doesn't work either. Only restarting the application helps.
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16267
  • Vital
This changes Form.WindowState. But visually, the form remains unchanged.
Form.WindowState: = wsFullScreen works correctly. But then the window overlaps the OS Control Panel. This doesn't suit me.
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16268
The questions are
Which OS ?
Which Platform ?
Which CPU ?
Please give us some info
CodeTyphon support 9 OSes
200+ CPU-OS-Platform
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16269
  • Vital
OS: KDE Neon (or Kubuntu 21.X)
OS Build: 5.22 (or 23)
CT: 7.6 (QT5)
CPU: x86_64
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 2 weeks ago #16270
  • Vital
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 1 week ago #16284
  • Vital
The problem is observed in session X11. In Wayland is working correctly.
Alternative for BorderStyle = bsNone + WindowState = wsMaximized 5 years 1 week ago #16285
