Problem with Lazarus Library in CodeTyphoon 6 years 2 months ago #15073
  • TECHNOLOG
  • TECHNOLOG's Avatar Topic Author
Hi to all,
I have a commercial library from Elevatesoft.
Converting the x64 Library to Codetyphoon give me a compiler error:
edbcommon.pas(1443,89) Error: Call by var for arg no. 6 has to match exactly: Got "QWord" expected "LongWord"
The code line is
FThreadHandle:=BeginThread(nil,0,@ThreadProc,Pointer(Self),CREATE_SUSPENDED,FThreadID);
I have tried to convert the QWord to Longword with the following code
FThreadHandle:=BeginThread(nil,0,@ThreadProc,Pointer(Self),CREATE_SUSPENDED,longWord(FThreadID));
result in the following compiler error
edbcommon.pas(1443,99) Error: Can't take the address of constant expressions
Any idea how to get the x64 library to work? We develop only x64 Applications, so using x86 Application is not possible and not tested.
Thank you in advance.
Problem with Lazarus Library in CodeTyphoon 6 years 2 months ago #15074
Try
PtrInt( or
PtrUInt(
Problem with Lazarus Library in CodeTyphoon 6 years 2 months ago #15075
  • TECHNOLOG
I got the following errors
FThreadHandle:=BeginThread(nil,0,@ThreadProc,Pointer(Self),CREATE_SUSPENDED,PtrInt(FThreadID));
edbcommon.pas(1443,97) Error: Call by var for arg no. 6 has to match exactly: Got "Int64" expected "LongWord"
FThreadHandle:=BeginThread(nil,0,@ThreadProc,Pointer(Self),CREATE_SUSPENDED,PtruInt(FThreadID))
edbcommon.pas(1443,98) Error: Call by var for arg no. 6 has to match exactly: Got "QWord" expected "LongWord"
Problem with Lazarus Library in CodeTyphoon 6 years 2 months ago #15076
More Info Sir
FThreadID is TThreadID
what type is FThreadHandle ?
a code Sample ?
Problem with Lazarus Library in CodeTyphoon 6 years 2 months ago #15083
  • TECHNOLOG
Because it is a commercial library, I prefer to PM more information to you and not via Forum.
As Moderator, please send me a message to my email and I will send you more information by email.
Last edit: by TECHNOLOG.
Problem with Lazarus Library in CodeTyphoon 6 years 2 months ago #15084
Sorry Sir
it's commercial library, so we can't help you,
If you are NOT the owner of the Library.
If you are the owner of the Library,
you can first send an email
to This email address is being protected from spambots. You need JavaScript enabled to view it. without any source
to discuss this.
