How to translate library resource strings? 6 years 10 months ago #14276
  • Roman
  • Roman's Avatar Topic Author
I am creating a library (simplified example):
library my_library;
uses LCLTranslator;
resourcestring
  LibraryDescription = 'My test library';
function GetLibDesc : string; cdecl; export;
  Result := LibraryDescription;
exports
  GetLibDesc;
initialization
  // How to do translate resourcestring to 'ru' ?!
  SetDefaultLang(''); // no effect!
end.
I can’t understand how to use LCLTranslator.SetDefaultLang (or any other???) so that my function returns a description in the default OS language? my_library.ru.po-file created and placed in the same directory as the library.
Need help!!!
How to translate library resource strings? 6 years 10 months ago #14277
Did you look the source of
codetyphon\CodeOcean\aa_LCLBasics\samples\multilang\multilang.ctpr
How to translate library resource strings? 6 years 10 months ago #14278
  • Roman
My project do not include any Forms, LCLTranslator generate many compilator errors like "Undefined symbol WSRegisterxxxxxxxx ..."
How to translate library resource strings? 6 years 10 months ago #14279
Your library must have
"Interfaces" to use LCLTranslator unit
How to translate library resource strings? 6 years 10 months ago #14280
  • Roman
Sternas Stefanos wrote: Your library must have
This does not help: DLL is not processed, resourcestrings are not translated.
How to translate library resource strings? 6 years 10 months ago #14281
  • fredvs
  • fredvs's Avatar
Imho, LCL is not suited for libraries.
It has to much dependencies.
How to translate library resource strings? 6 years 10 months ago #14282
  • Roman
fredvs wrote: Imho, LCL is not suited for libraries.
I agree. And what in this case to do?
Last edit: by Roman.
How to translate library resource strings? 6 years 10 months ago #14283
  • fredvs
  • fredvs's Avatar
Try to use only units with less dependencies.
What do you want to achieve?
If you want to work with po files, you only need text-stuff dependencies.
I did not check yet LCLTranslator unit but maybe you can use some methods from it in your library code, without the need to link to all LCL stuffs.
The following user(s) said Thank You: Roman
How to translate library resource strings? 6 years 9 months ago #14311
  • Roman
I solved my problem like this:
  S : string;
initialization
  S := GetModuleName(hInstance);
  S := ExtractFilePath(S) + 'lang\' + ChangeFileExt(ExtractFileName(S),'.%s.mo');
  TranslateResourceStrings(S);
Maybe this is a stupid solution, but it works :whistle:
