XML to JSON conversion in CT 5.5 10 years 10 months ago #8698
  • Md. Shariful Alam Khan
Is there a easy way to convert XML to JSON?
XML to JSON conversion in CT 5.5 10 years 10 months ago #8699
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
you could have a look at this documentation and the Wiki page .
Anyway, be aware that with JSON, all the items don't necessarily follow the order of elements defined with XML (unless they are elements of an array).
So, XML is not totally "compatible" with JSON.
